Least Expensive way to Monitor A/F - Wideband 02
Old Jul 14, 2010 | 03:40 PM
SRT6_Roadster's Avatar
Default Least Expensive way to Monitor A/F - Wideband 02
I am looking for suggestions on the least expensive way to monitor my A/F ratio on the street. This is not something I am looking to run all the time - basically I want to monitor my car under a number of circumstances to make sure the ratios are good. Then I plan on pulling the system out.
I could go with something like this: Innovate Motorsports Wideband LC-1 LC1 O2 Kit 3769: eBay Motors (item 230493821231 end time Jul-29-10 21:48:51 PDT)
The issue being how to I then log the A/F against RPM?
Old Jul 15, 2010 | 12:17 AM
HyprLtH20's Avatar
www.CustomCrossfire.com
Default Re: Least Expensive way to Monitor A/F - Wideband 02
You could buy one of my pillar pods and put in a wideband AFR gauge
Old Jul 15, 2010 | 01:12 AM
NeedsWings's Avatar
this is the one you want
Zeitronix Zt-2 Wideband Controller
we cant get to the cheapness of the one linked above but we can do a little better then normal for you.
are we ready to start up a zeitronix group buy?
Old Jul 15, 2010 | 08:42 PM
I am all for a group buy but can the Zeitronix you reference plot A/F to RPM or do I need additional parts for the logging?
Old Jul 15, 2010 | 11:17 PM
NeedsWings's Avatar
yes the base zeitronix kit will do afr, rpm and tps without the purchase of anything else (other then a little wire/solder to connect in the signal). if you have an old k-type thermocouple laying around you can feed that in for the EGT. i would surely recommend the boost sensor option for a srt6 though.
Old Jul 16, 2010 | 07:52 PM
What does the boost sensor option run?
Old Jul 16, 2010 | 07:58 PM
dag gonnit Rob, I am saving for a rear end, and you come up with a tickler like that....well, how much if a group gets together?
Old Jul 16, 2010 | 08:43 PM
Infinite's Avatar
I run the AEM UEGO on my race cars, simple. just a gauge and a sensor. has a 0-1v preout and a 0-5v so you can datalog.
http://www.buyimportperformance.com/..._p/30-4100.htm
for dual o2 sensors (like we have) we run this. FAST dual wideband. It can read individually, or average them. Its been one the best ones we've run with the z06 and havent had an issue yet
http://www.rpmoutlet.com/mt.htm
the one in the top right corner
Old Jul 16, 2010 | 09:37 PM
32krazy!'s Avatar
dont forget to add about 50$ to have the bung welded into the exhaust manifold.
i have the zt-2 connected to a dashdaq and its a great real time afr tool
Old Jul 16, 2010 | 11:27 PM
MikeR's Avatar
and for reading and clearing DTC's ........
Old Jul 17, 2010 | 11:41 AM
Eric's Avatar
or a friend with a welder and a M-18 nut
Old Jul 17, 2010 | 04:27 PM
ChuckNorris's Avatar
LM1 is cheap and is set up to emulate the narrowband out of the box.
Old Jul 17, 2010 | 04:46 PM
Already have an 02 bung installed.
With the AEM UEGO I don't see anyway to log A/F against RPM without a data logger. Same issue with the FAST unit.
The LM1 looks like it would fit the bill but is a bit more than the Zetronix unit. How do you hook this up to graph against RPM? Do I need to purchase the RPM kit or is there another way?
It looks like the Sniper AF-5000 would work also.
Old Jul 17, 2010 | 07:43 PM
HellFire's Avatar
Or a cell phone/video recorder. If you have the guages near enough and do not want a permanent system and are just looking to match your readings with your rpms.... That's called a ghetto logger. LOL
Old Jul 17, 2010 | 10:06 PM
Infinite's Avatar
the fast unit logs internally, you just have to buy the rpm module.
the aem has to be externally datalogged.
Old Jul 21, 2010 | 04:14 PM
70GS455's Avatar
PLX Devices Inc. - Multi Gauges, Single Gauges, Sensor Modules, Wideband Air Fuel Ratio, Data Logging, Fuel Saving / Scan Tools
PLX, has extra cost datalogger.
Old Jul 23, 2010 | 09:04 PM
Still trying to learn here and make an informed decision.
So I get the PLX and it logs the A/F ratio and can support a number of other sensors. What do I use to monitor RPM?
Kodebuster
Nov 5, 2020 04:06 PM
SRT6_Roadster
Sep 24, 2015 04:40 AM
tritongreen
Sep 18, 2015 07:32 AM
user 8202
Canada
Sep 1, 2015 11:43 AM
nickwe21
39
Jul 31, 2015 01:48 PM
