Abnormally low gas mileage
Old Jul 30, 2010 | 12:25 PM
luketastic1's Avatar
Exclamation Abnormally low gas mileage
Hey, [Abnormally low GAS**** MILEAGE**** sry....]
I just got an 04' Xfire AT w/ 26k miles on it. Oil needs changing along with a new filter (fleece, I know) and I wanted to know if that is maybe the only reason i'm getting about 13mpg... I've been using an immensely light foot with it to see if it yields better performance in MPG with no avail.
Any advice?
Cheers!
Old Jul 30, 2010 | 12:51 PM
Larry Hitze's Avatar
Default Re: Abnormally low milage.
I doubt that needing an oil change will cause that. I drive somewhere between grandpa and enthusiastic and I still get 21 to 22 in town with a stick.
Old Jul 30, 2010 | 01:00 PM
Default Re: Abnormally low mileage.
So, any ideas? Spark plugs? fuel filter?
Old Jul 30, 2010 | 01:04 PM
I wouldn't think that spark plugs or the fuel filter would be bad at 26,000 miles. I'm no mechanic by any means, but first off I would check the air filter to see if it is dirty or clogged. Maybe someone else here has any more ideas.
Old Jul 30, 2010 | 01:18 PM
OKC-XFR's Avatar
The mpg on mine slowly started dropping around 30,000 miles - never got lower than 19 mpg, but it normally was getting 24 mpg. I changed the plugs and wires with irridium plugs and Magnecor wires and it jumped right back up to normal. When I inspected the old plugs and wires, I couldn't see anything wrong, but there must have been something...
Old Jul 30, 2010 | 01:21 PM
I have 47,000 miles with the original plugs, wires and battery and I get great mileage and it runs perfectly. Probably not going to be safe with that battery soon though.
Hey sorry for the noobish question,
but what wires did you replace?
Old Jul 30, 2010 | 01:23 PM
Also is there a link you could provide to those Iridium plugs?
Old Jul 30, 2010 | 01:26 PM
Are there signs I can look for that would indicate a bad air filter? Also, any good names or part #s I should look for to replace it?
Old Jul 30, 2010 | 01:28 PM
Just take them off and look at them. Dirty you can see, besides it doesn't hurt to change them every once and a while. I have K & N replacement filters I can't remember the part #. I got them on ebay, you can look the number up on K & N's website. However stock one's will do nicely at cheaper cost you can get them almost anywhere. Remember that there are two of them.
Old Jul 30, 2010 | 01:30 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Abnormally low gas mileage
~ most likely 2 really dirty air filters...
an ebay link for 2 k&n filters: http://cgi.ebay.com/ebaymotors/04-05...Q5fAccessories
also i would use premium fuel as intended.
Old Jul 30, 2010 | 01:31 PM
OKC-XFR's Avatar
No problem at all - they were the spark plug wires...
I got them from NeedsWings here:
Product Category Listing
I got the Magnecor KV85 8.5mm Competition Ignition Cables and NGK Iridium IX Spark Plug Set (1 heat range colder).
Old Jul 30, 2010 | 01:47 PM
Thanks for all the awesome responses and suggestions.
Gonna check the air filters now and get back soon
If anyone else has anymore ideas feel free to shoot!
Cheers!
Old Jul 30, 2010 | 02:15 PM
an ebay link for 2 k&n filters: 04 05 06-08 Chrysler Crossfire K&N Air Filters Pair New: eBay Motors (item 310237254770 end time Jul-31-10 12:07:12 PDT)
I think that is the company I bought mine from Andrew, if I remember right they got here fast.
Old Jul 30, 2010 | 02:39 PM
Yeah it actually looked like there was sand in the air filter and debris from some wild forest...those F*#ckers were DIRTY! Hopefully that was my problem...
Old Jul 30, 2010 | 04:41 PM
Well it won't hurt it to change them
Old Jul 30, 2010 | 05:29 PM
For sure! Although can some dirty air filters really cause such a dramatic loss in MPG?
Old Jul 30, 2010 | 05:41 PM
kurtisberry's Avatar
Went I replaced my OEM air filters with K&N, mileage dropped about 10%. Went from 20 city to 18 and 25 HW to 22. Have since, at five years and 35K, had the fuel filter changed as well as trans service. No difference. I'm thinking of going back to the paper filter just to see if it makes a difference.
Old Jul 30, 2010 | 09:45 PM
Well one thing for sure, we will find out when you change yours.
Old Jul 31, 2010 | 12:59 PM
Bladecutter's Avatar
Yes, they can.
Remember, if the air filters aren't clean, the engine strains to run properly, and if they are bad enough, the computer is slow in adjusting the fuel mixture, which means you are running richer than you typically would be, anytime you change throttle positions.
You need new filters, if you haven't replaced them already.
New spark plugs and wires might be something to consider in the future, but not needed for a bit.
BC.
