Lighting mod - what do you guys think?
Old Aug 15, 2010 | 11:19 PM
Az4R1's Avatar
Default Lighting mod - what do you guys think?
Here are some pics... light strip goes under headlight housing, just above the bumper. Barely visible during the day when the strip is off.
-Az4R1[IMG]file:///C:/Users/ThinkPad%20X61%20Tablet/Desktop/IMG00288.jpg[/IMG]
Old Aug 16, 2010 | 08:21 AM
ZAHANMA's Avatar
Default Re: Lighting mod - what do you guys think?
...care to give us a little insight as to the what and the how...
would be greatly appreciated. thanks.
Old Aug 16, 2010 | 09:58 AM
Az4R1's Avatar
I found this LED light strip with "sideways" emitting on this website:
Audi A5 R8 Style LED Strip Lights | LED Headlights | LED Driving Lights
The strip itself is very flexible, about 3/16 inch thick. The strip is transparent obviously, with black backing. That was one of my primary concerns since I want it to blend in especially during the day. The only thing that I had to be careful was the spacing between the lights since the spacing is a little "off" every 3 LEDs or so since that's how the strip was put together.
For now, I have the strip wired to the side marker... the part I am now sure about is the durability of the strip in taking all the weather elements exposed to it.
-Az4R1
Old Aug 16, 2010 | 01:50 PM
Az4R1's Avatar
Here are some daytime pics... with the strip on and off.
-Az4R1
Old Aug 16, 2010 | 04:17 PM
You really need to replace both your upper corner bulbs and side marker bulbs with LEDs if you want those to remotely look like they came from the factory.....
Old Aug 16, 2010 | 06:34 PM
Az4R1's Avatar
I did actually, but I didn't like the light dispersion pattern of the LEDs so I went traditional amber bulbs. Perhaps I should try different style of LEDs...
-Az4R1
Old Aug 16, 2010 | 08:32 PM
mophreakous's Avatar
Looks good Az, was wondering when someone was going to do that....... Take long?
Old Aug 16, 2010 | 08:40 PM
Az4R1's Avatar
Thanks...! It took me about an hour, but I took my time placing the strip back and forth until I'm happy with the placement. Easy mod, for sure...
-Az4R1
Old Aug 17, 2010 | 08:57 AM
-Az4R1
I used a 6 LED bulb on the upper corners that all face forward, it is a nice pattern and looks quite OEM. For the side markers, I used a 5 LED bulb with 4 that emit in all four directions, and a fifth that shines straight out, it is a nice balanced light.....
Old Sep 10, 2010 | 02:00 PM
Kagen's Avatar
How did you wire the strip?
Old Sep 10, 2010 | 08:00 PM
HyprLtH20's Avatar
www.CustomCrossfire.com
you can plug the hot wire into a fuse and ground the other wire. Its just a simple 2 wire set up.
Old Sep 10, 2010 | 09:31 PM
soundcreationsaz's Avatar
I've had mine for almost a year and they were perfect in 10 below all the way up to 120 degrees. I was a test subject for plasmaglow and they have a lifetime warranty...pm me if you want a set!
gblack32
Sep 7, 2016 08:27 PM
Aug 18, 2015 12:52 PM
JEFASOLD
Jul 15, 2015 02:32 PM
Adrian_X
Jul 12, 2015 11:05 PM
bbsrt6
Jul 12, 2015 09:35 PM
