Air Conditioner Compressor
Old Sep 4, 2010 | 12:19 PM
shankb4's Avatar
Default Air Conditioner Compressor
2005 Coupe.
I am replacing the air conditioner compressor.
How & where do I bleed off the pressure in the lines?
Thank you for any help
Old Sep 5, 2010 | 11:28 AM
xfire2005's Avatar
Default Re: Air Conditioner Compressor
I subscribe to AllData DIY website where you can access almost ALL repair information for most cars.
It is 26.95 per year and gives multiple car discounts.
ALLDATAdiy.com :: Leading Source of Diagnostic and Repair Information
Old Sep 5, 2010 | 12:45 PM
kingkub57's Avatar
Legaly it should be recovered and then you can re-use it, but you have two lines for the a/c low pressure and high pressure, you connect R-134 gauges to them and just open the valve a bit and let it go, but then you have to get more freon and re-charge the system after your all done make sure you replace your seals/o-rings and such, and make sure your compressor has enough oil in it as well, see the sticky for shop manual and it should give you all the procedures for this repair.
Old Sep 5, 2010 | 12:58 PM
Get it removed at an auto AC shop, they will plug the lines so nothing contaminates the system, anything else is illegal and not good for the environment. This stuff is not so bad as the old stuff but ...
When you go back to the shop they can refill it like it should be done. With a new compressor you need it filled just right.
Old Sep 6, 2010 | 05:18 PM
shankb4's Avatar
Thank You. The link is what I can use.
I live in South Bend. Are you a ND fan?
Thanks again
Bruce
Old Sep 6, 2010 | 05:21 PM
shankb4's Avatar
Thank you for the info. You been very helpful.
Bruce
Old Sep 6, 2010 | 05:23 PM
shankb4's Avatar
Thank You very much. You have been very helpful.
Bruce
Old Sep 6, 2010 | 07:47 PM
waldig's Avatar
Talking Re: Air Conditioner Compressor
IS the alldata really of significant value?? Iam interested in the level of detail and factory information provided. Wouls this replace a mercedes manual?? Thanks Woody
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
Sep 28, 2015 07:40 PM
81's
Sep 13, 2015 04:34 PM
BEATv1
Sep 10, 2015 12:58 PM
