lantana you wanted a key start!!
Old Sep 12, 2010 | 03:28 PM
32krazy!'s Avatar
Default lantana you wanted a key start!!
Lorinser Mercedes SUPERCHARGER V8 KOMPRESSOR FULL KIT : eBay Motors (item 200518423121 end time Sep-18-10 10:30:00 PDT)
Old Sep 12, 2010 | 05:26 PM
LantanaTX's Avatar
Default Re: lantana you wanted a key start!!
Wow, that looks interesting...
Old Sep 12, 2010 | 05:32 PM
32krazy!'s Avatar
definatly different! maybe rudy can fix it so it starts witha key price isnt to bad. think itll fit under your hood?
Old Sep 12, 2010 | 08:51 PM
LantanaTX's Avatar
This one is a centrifigal supercharger which is basically a belt driven turbo. I had considered this type of boosting and had pretty much ruled it out. One of the problems with boosting a n/a engine is compression that limits the amount boost as well as the heat of the charged air. superchargers really heat the air. One thing nice about a rear mount turbo is the charge is much cooler by the time it gets to the engine. Adding an intercooler isn't usually even needed in a rear turbo. A cooler charge allows more boost and HP. A rear mount turbo probably has the greatest HP potential and may be the cheapest way to go as well.
Another option is HPS generation 1 or 2 superchargers. They are nice units but their reputation is not so good right now and people are selling them cheap. From what I have been able to read the supercharger are fine but tuning is not. HPS uses a rising rate fuel pump to keep the engine from leaning out but guys have blown a few engines and dumping the kits cheap. I am tempted to buy one of those units and tune it properly. The rear mount turbo and the tuning approach that Rudy and I have in mind would be applicable to any n/a V6 as well and would be very cost effective.
Old Sep 13, 2010 | 09:14 PM
JimmySkullz's Avatar
Or This?
Selling Kleemann Supercharger & Headers - MBWorld.org Forums
Old Sep 13, 2010 | 09:29 PM
32krazy!'s Avatar
Originally Posted by JimmySkullz
shsssshhhhh its a secret!!
Old Sep 13, 2010 | 09:39 PM
LantanaTX's Avatar
Thanks! that is not a bad deal with the Headers and the whole kit. I sent a PM to him.
Old Sep 13, 2010 | 09:45 PM
32krazy!'s Avatar
already sent it to rudy and told him to pass it on to you. 6k is killer deal with the headers!
Old Sep 13, 2010 | 10:18 PM
LantanaTX's Avatar
I am pretty sure the headers are wrong for my car though. But I was looking at a new HPS system today for $6.600
Old Sep 13, 2010 | 10:36 PM
Looks like he might not be selling the headers.
Old Sep 14, 2010 | 01:42 PM
MAXIMUSQUO's Avatar
Just wonder if would be fit on my 5.5 V8........will ask the guys fo more information.
regards V8Max
Old Sep 14, 2010 | 07:42 PM
LantanaTX's Avatar
regards V8Max
Max!! Good to see you on here. The Lorinsor should work just fine. Max, you may also want to consider the Kleeman link as well. I talked to the guy today and have decided to go a little different route.
I spoke to Andrew Atwood in Airizona at Atwood European and like what they are doing with their system. What do you guys think of this? Super charged normally aspirted 55. This system will go right on your car MAX and the tuner has guys in the USA and Germany with proven software for your 55 and my 500.
Old Sep 14, 2010 | 08:57 PM
32krazy!'s Avatar
i like the center peice! whats it off of?
Old Sep 14, 2010 | 09:09 PM
LantanaTX's Avatar
Are you talking about the engine cover/filters? the nose piece is from the original engine cover. this is an early n/a E55. The air filters are SL55 I believe. The red center thing is a supercharger with a top mounted air to water inter cooler. It has a SL55 heat exhanger in front of the radiator.
Old Sep 14, 2010 | 09:11 PM
there's a whole lot HP being put into these little babies....the all new 2010 V-8 compressor Crossfires....being produced by "A few good Men".....lol
Old Sep 15, 2010 | 11:31 AM
Did you get a new toy??
Old Sep 15, 2010 | 11:49 AM
LantanaTX's Avatar
I am going with the super charger in the picture. It is based on the HPS system. HPS had trouble with tuning in the past as well as some DIY'ers that didn't install it correctly causing some blown engines. This has cuased a lot of negativity on the MB forums. They changed tuners are a couple of years ago tp top German tuner for the ECU work. The advantage to me is that the Germans have installed some V8"s in SLK's in Germany and have fixed the key start issue. Atwood is a HPS dealer but has done a lot additional developement work to really get the power up safely. One improvement is in the picture above which is a very large heat exchcanger that allows more boost.
I really liked the Tubo idea but this set up is clean, proven and doesn't require near the fabrication work of a one off turbo set up. Also the support from Atwood is very valuable to me as well. With the right mods I could get into the mid 400HP range at the wheels. One key mod will be long tube headers which add about 40hp on this set up.
Old Sep 15, 2010 | 11:05 PM
Awesome! My friend lives right near the shop in Arizona, they always have a sick setup of cars being worked on,... at least when I was out there. I think this will be a better set up than the stock 55K engine as far as money spent.. Good Luck Bro! cant wait till you have this finished
spoiler
Sep 2, 2015 08:56 PM
gtjl
17
Jul 22, 2015 06:28 PM
bdh
Jul 9, 2015 09:40 AM
gtjl
Jul 8, 2015 07:42 AM
Fildo Dog
Jul 6, 2015 05:20 PM
