Carbon fiber key fob
Old Nov 1, 2010 | 11:51 PM
huntsmcgee's Avatar
Default Carbon fiber key fob
So i got my sample pc of 3m di-noc wrap in today and since i had already orded the 4ftx5ft roll i put it on my key fob. Turned out ok not perfect but still pretty cool. Btw i was going to put the 3m di-noc on my headliner but instead ill put it on the interior trim and center consol and use black suede for the headliner and pillers.
Old Nov 2, 2010 | 07:36 AM
ImportLabSRT's Avatar
Default Re: Carbon fiber key fob
I was thinking of doing the same thing with all the silver interior accents. But I dont trust myself to do it, I was going to have Graphix Zone in Roselle,IL do it for me.
Old Nov 2, 2010 | 08:59 AM
Looking good, Hunts.
Brian, if they end up doing it, let me know. If the work id good and the price right, I would drive up and have them do mine as well. I just don't trust myself with that stuff either.
Old Nov 2, 2010 | 10:40 AM
AaronNWeikart's Avatar
This looks fantastic! I really hate my key-fob. The plastic is ugly, and the entire thing looks so cheap. Maybe this can be perfected for an easy fix to an ugly design.
Old Nov 2, 2010 | 12:15 PM
I wil let you know and send pictures if/when I do so.
Hunts ~ Keep us updated, I know a lot of us are antsy to see how it turns out.
Old Nov 2, 2010 | 12:40 PM
huntsmcgee's Avatar
I will be sure to post pictures, Theres alot of little things im going to do with the carbon fiber wrap. So when that comes in and then suede is done ill take some pics
Old Nov 3, 2010 | 12:15 PM
I know you used the di-noc and I have not seen any in person. Is it fairly flexible to contour around edges and sharp curves? Did you use the 3m adhesive or what? I was going to try to do my fob, but I think I would make an effing mess of it LOL
Old Nov 3, 2010 | 02:31 PM
Jason_HBC's Avatar
John
The 3M material is the same material that Max and I both used to do our center consoles prior to the Dragon this year. The material is very flexible and becomes extremely easy to use especially once it has been heated. The problem with the interior is the center stack is extremely complex with its various curves, convex/concave surfaces, and openings for the switches.
I like how my interior looks, but in same breath I wish there was a way to do the main piece. I know Rockstar on 96th St is an authorized 3m installer and they may be able to do the install.
Jason
Old Nov 3, 2010 | 11:14 PM
huntsmcgee's Avatar
When you say you wish you could do the main part are you talking about the center of the dash everything around the radio although it does look hard ill be trying to do it tommarow. So far i have the door handle/tweeter cover, Coverd. the storage lid in the middle is coverd but the rest will be done tommarow
Old Nov 4, 2010 | 06:45 AM
Jason_HBC's Avatar
Hunts, that is the piece I am referring to. The piece that covers the heat/ac control, the switches, and radio. The problem I ran into is the thing is so darn complex that the vinyl wants to return to its original position. The only set up that seems to get it right is the process used by SRT-Six, Karl. I do not believe that he uses the 3M process.
When I saw Max's car, the lip that is immediately below the switch had an area in which the 3M had pulled away from the panel. I also had this happen and tried applying three different ways. Good luck! Make sure your piece is very clean and use the 94 tape primer. That should help you as well.
Jason
Old Nov 4, 2010 | 08:23 AM
Jason, that is what I am worried about, spending all that time and effort, not to mention having the adhesive all over the parts and possibly scratching them in the process. I have wanted to do some stuff with the wrap, but until I find someone I trust at a reasonable rate, I will not be undertaking this.
Old Nov 4, 2010 | 08:18 PM
huntsmcgee's Avatar
Ok so im done with the 3m carbon fiber job, First off its not perfect but its very close. Around the corners its pulled away just a tad bit but it does not look bad i would be the only one to know im sure. and othere than that its flawless.
Old Nov 4, 2010 | 09:31 PM
Jason_HBC's Avatar
Nice work with the 3M. I ended up pulling off the vents and the piece below and I have grown to like my contrast.
Old Nov 4, 2010 | 09:56 PM
downwardspiral's Avatar
I usually hate the way this stuff looks, but that looks great! It totally changes the feel of the interior.
Old Nov 5, 2010 | 08:21 AM
Looks very good, Hunts. I think if I go this route, I will have to change out the switches and toggles for black ones like beaner did, the silver now looks slightly out of place IMHO.
Old Nov 5, 2010 | 08:59 AM
huntsmcgee's Avatar
OK. well this morning i went for a drive and the little corners were driving my ocd crazy. since i knew they where bubbled out from the edges so i took my fiber nail to try to push it back in"that never stays" and made a slight tear in the viynle. Me being ocd about things like this made me mad. So in order to get ride of the bubbling around the complex corners i simply cut it so it would lay flat and went back with what i call vinyle patchs to cover up any silver that might now show. The patchs you cant see if you match the pattarn up just right and heat it up. So now my corners look good and i dont have to worry about that. just thought id let yall know
fastfred
Nov 5, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Padgett
Southeast Forum
Sep 27, 2015 09:37 AM
xjken
Sep 13, 2015 10:18 PM
