Install a N/A BCM on a SRT
Old Oct 29, 2010 | 06:03 PM
FUBU's Avatar
Default Installing a N/A wing onto a SRT
Hi,
Have anyone done this before? Installing a N/A wing on a SRT must be possible..
I would like it to be automatic.. extend over 60mph... Please PM me if you are interested in maybe changing your N/A wing and motor etc. to my SRT wing. (Have not purchased the car yet but I will and need to know if this is possible)
/ Phil in Sweden
Old Oct 29, 2010 | 07:01 PM
CrossfireLTD's Avatar
Cool Re: Installing a N/A wing onto a SRT
I believe a few members have done so with success. You would have to swap out your SRT6 trunk/deck lid and spoiler for their N/A trunk/deck lid. I am sure you have already figured this out. I have no doubt that someone will take you up on your offer.
Old Oct 29, 2010 | 07:05 PM
Jackson5's Avatar
Default Re: Installing a N/A wing onto a SRT
You only need to switch out your wing and filler/mounting panel for the wing assy. No need to switch the entire hatch. I am about to try it myself and researched it out.
Old Oct 29, 2010 | 08:56 PM
His SRT would need the entire N/A trunk/deck lid because of the wing motor and in turn to cut down on installation work on the N/A he can just install the entire SRT wing/trunk/deck lid.
Old Oct 29, 2010 | 10:36 PM
FUBU's Avatar
Hi,
I am amazed that there is no section about this. Sounds way easier just to switch the wing. But hey, i am no specialist. This have to be done prior my painting though...
Old Oct 29, 2010 | 11:18 PM
Originally Posted by FUBU
Hi,
In order to have the N/A spoiler actually work, activate and look right you would have to swap out your SRT trunk/deck lid. On the N/A deck lid there is an indented area where the spoiler sits when its not activated, also the spoiler motor sits underneath the deck lid.
Old Oct 29, 2010 | 11:53 PM
JHM2K's Avatar
Don't forget you'll need the N/A BCM... The SRT BCM doesn't have the programming to deploy the spoiler at a given speed, because the SRT spoiler is always deployed.
According to several sources I've seen, the BCM on the SRT allows a bit more "on the edge" handling since the engineers knew the car had sportier and firmer suspension. So, you may very well cripple your handling ability a bit by switching to the N/A BCM. It's simply a setting that allows just a bit more sideways action before the computer arrests your fun.
Old Oct 30, 2010 | 01:40 AM
FUBU's Avatar
Sounds difficult. I tought I could only switch the actual wing, do a bit of wiring and make at least a manual switch....
Old Nov 9, 2010 | 02:54 PM
FUBU's Avatar
Default Install a N/A BCM on a SRT
Hi all specialists,
I hope you and your cars are all well. I am on the quest for having a N/A wing on the SRT coupe. Preferably to have it automatically go up and down at the specific speeds.
What will be the most effecient
1. Insert a BCM from a N/A to my SRT
2. Reprogramme the SRT BCM somehow telling it that it should deploy a rear wing..
Carrying out 1, could it have any bad effects on other areas? Is it even possible to have a N/A BCM?
2. Who does the reprogramming?
Thanks for all your comments. I am amazed that no one has ever done this. The one who helps me get this to work may well be getting my SRT rear spoiler, if I get his N/A that is
4drturbo
Jan 3, 2019 02:46 PM
Roty135
17
Oct 11, 2018 10:11 AM
shawnwatson9493
Jul 9, 2015 11:47 PM
bdh
Jul 9, 2015 09:40 AM
bradleykologek
Jul 6, 2015 02:49 PM
