Headlamp (bulb) failure
Old Nov 18, 2010 | 08:07 PM
Raven_flstc's Avatar
Default Headlamp (bulb) failure
Good evening. First time to post. My Crossfire is a 2007 Black/Black 6 speed 40,000 miles. The drivers side low beam bulb has failed again. It is the third time in 18 months. What would cause this? I appreciate any information. Thanks!
Raven
Old Nov 18, 2010 | 08:57 PM
Default Re: Headlamp (bulb) failure
Raven
What brand?
Also connector bad contacts can cause premature failure.
Check the fuse for that bulb, maybe it's not making a good contact.
As it is limited to one side I do not think it is voltage spikes.
Old Nov 18, 2010 | 09:38 PM
Sylvania and/or Phillips were the first two, which I replaced myself. The last one was put in by the mechanic I use since I took it in to check for an electrical problem that might be the cause. I know they used a high end bulb, but it's only lasted maybe three months. I'll be sure to check the fuse and connector when I replace it this go around. Thanks!
Old Nov 18, 2010 | 10:13 PM
robby363's Avatar
Were they Sylvania silverstar?
Old Nov 18, 2010 | 10:27 PM
Looking up the Sylvania Silver Star bulbs, the last ones that I purchased were the Ultras (with the gold stripe on a red package - $50 for 2). Prior to those, I believe were one of the Philips H7 bulbs, but not positive which ones ($40 for 2). The last one the mechanic put in did not list the brand on my receipt, but I could probably get the info. I do know he stated it was a high end bulb, and it did outlast either of the previous bulbs.
Old Nov 18, 2010 | 10:41 PM
robby363's Avatar
The silverstar bulbs are great while they work but are known not to last long. I've used them in 2 cars and was lucky if I got 6 months out of them.
2004_
Jul 9, 2025 12:39 AM
Nexxus
May 8, 2016 04:43 PM
xfClifford
27
Nov 10, 2015 10:08 PM
toob
Sep 26, 2015 11:44 AM
maxcichon
Sep 4, 2015 12:50 PM
