Backup Camera
Old Nov 26, 2010 | 09:35 PM
TomStratRT's Avatar
Default Backup Camera
Has anyone successfully installed a backup camera on their Crossfire? I tried to install the Pyle 3.5" one today by wiring it up to the reverse lights and it won't come on when the car goes in reverse. I tested the wiring using a voltmeter and the wiring is getting power, but the camera doesn't turn on. I'm hoping I didn't get a bad unit.
Old Nov 27, 2010 | 03:48 AM
Default Re: Backup Camera
The wires are hooked up correctly? If you have the wires on the wrong terminal sometimes the electricity cannot flow in that direction due to a diode. Silly answer maybe but that's my only suggestion, sorry.
Old Nov 27, 2010 | 08:24 AM
Is this a "hard" wired unit and not wireless? I have used the wireless units, and tied into the backup wire...but not any hardwired units...
Old Nov 27, 2010 | 03:25 PM
mdaniels4's Avatar
I have a wireless in and it's fine. I scraped the insulation from one of the reverse wires, wrapped the bare ends around that and then taped it all up. Check which wire you have it on.
Old Nov 27, 2010 | 03:33 PM
TomStratRT's Avatar
It's a hardwired unit. I'm piggybacking off of the brown wire from the reverse lights for the positive and put the ground on the bolt holding the taillight in.
Is this the right method?
Old Nov 27, 2010 | 03:46 PM
Can you get a curcuit with the brown wire and the ground you are using? I am not too sure but if the bolt is in the light unit it may not be grounded.
Whats wrong with using the tail light ground wire?
Old Nov 27, 2010 | 04:00 PM
TomStratRT's Avatar
The tail light is bolted to the body which is metal. It's easier and cleaner to do this than cutting into another wire. There are three wires coming from the reverse light socket, two black wires and one brown wire. I'm getting power to the wiring when using a voltmeter while in reverse, but the camera and monitor are not powering on. I don't get it. I have some experience with working on 12v accessories and custom wiring, and I'm stumped.
Old Nov 27, 2010 | 05:04 PM
Lakeview NY's Avatar
Check the settings on the monitor, when I put mine in after x-mas I will put my ground wire right to the body. I had one on my last ride. I only tapped into power wire for turn signal. I have 5" indash monitor.
Old Nov 28, 2010 | 12:21 AM
mdaniels4's Avatar
I think that's the problem Tom, not getting a good ground. I stripped both wires and wrapped them separately so they made a complete circuit.
Hoppy
Dec 7, 2018 07:36 AM
ala_xfire
Sep 28, 2015 05:51 PM
waldig
Sep 17, 2015 10:35 AM
RacerXofFL
Sep 15, 2015 05:00 PM
xfireon20z
Jul 20, 2015 04:35 PM
