Condensation Headlamp Kit - Changed Headlamp Design?
Old Feb 20, 2011 | 05:39 PM
wpetraska's Avatar
Default Condensation Headlamp Kit - Changed Headlamp Design?
Hey guys.
In an attempt to get over my utter hatred for winter, I went out to the storage space and installed the Condensation in Headlamp TSB kit. When I took a look at my headlamps, I noticed that the two smaller hose vents that I was supposed to plug with the two small caps, mine weren't there. The notches were there but there were no actual openings. It looks like they just changed the design the cover up the holes, meaning the two large plugs were all that control any actual venting.
Did they change the headlamp design for the later models? I installed the new large plugs and that was all.
Old Feb 20, 2011 | 08:44 PM
bluecoupe's Avatar
Default Re: Condensation Headlamp Kit - Changed Headlamp Design?
Headlamp Re-design To Accomodate Vents In 2006
Old Feb 21, 2011 | 08:55 AM
'Headlamp Re-design To delete Vents In 2006'
Old Feb 21, 2011 | 09:35 AM
bluecoupe's Avatar
The 2006 headlamps were re-designed with the same type of vent the TSB caps have. The "vent" is now integrel with the headlamp housing and the caps are solid rubber, rendering the TSB caps redundant.
Old Feb 21, 2011 | 09:52 AM
I do not understand.
Old Feb 21, 2011 | 09:53 AM
wpetraska's Avatar
That's strange but I had the same vent caps that the older Crossfires had (the new ones had the small rectangle, the ones on the car did not). Interesting... Plus I still had a TON of condensation regardless if they changed the design or not.
Old Feb 21, 2011 | 10:41 AM
bluecoupe's Avatar
Dave, the headlamp at the top of the picture has a manufacture date in 2003, the one at the bottom of the picture has a manufacture date in 2006. The 2003 headlamp has the white vent tube and solid rubber caps, no TSB kit. The 2006 headlamp has been redesigned, no white vent tube but it now has the rectangular vent on the housing that the TSB kit provides with the replacement rubber cap.
Old Feb 21, 2011 | 10:44 AM
wpetraska's Avatar
Thanks for the pictures! I wonder why mine were still so foggy?
xfireohio
Jul 20, 2020 12:03 AM
waldig
Sep 2, 2015 11:02 AM
Rets
Aug 23, 2015 06:31 PM
waldig
Jul 20, 2015 08:10 AM
UNDER PSI
Jul 18, 2015 02:12 PM
