MODS on crossfire question!!!
Old May 3, 2004 | 04:55 PM
04crossfire's Avatar
Default MODS on crossfire question!!!
does anyone know where they make aftermarket boltons like exhaust, coldairs, chips, etc. what a good website to go to , thanks
Old May 3, 2004 | 06:17 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: MODS on crossfire question!!!
http://www.ctd-germany.com have some accessories.
Old May 3, 2004 | 06:30 PM
WesMichaels's Avatar
Default
You already have cold air intake. Add K&Ns if you want to make it breath better. For a chip I've got the Upsolute chip remap and it's working great ( www.upsolute.com). Let me know if you're interested and I'll give you all the particulars. Or do a search in this area for "Upsolute". There are several threads. As for exhaust, I think Borla will have a system out very soon, if it's not out already.
Old May 4, 2004 | 12:03 PM
James Sonne's Avatar
Default
Most SLK320 parts should fit on the Crossfire without any trouble.
Old May 4, 2004 | 12:17 PM
Default
I'm pretty sure the exhaust is setup a little different on the Crossfire, since the SLK exhuast doesn't exit at the center of the car. That will require a system made especially for the Crossfire.
Old May 4, 2004 | 12:29 PM
Heb80's Avatar
Default
no biggy... with the help of a hammer and a brick and you'll have that thing fitting like a glove.... cave man style!
Old May 4, 2004 | 05:20 PM
Default
Intake mods should all be the same, though. Not sure, but it would be my guess.
Old May 4, 2004 | 06:25 PM
Default
But, and I'm here to tell you...... if you don't lower your compression and you plant a blower on this bad boy you are going to be driving a bomb looking for a place to blow.
Old May 4, 2004 | 06:42 PM
Default
The compression really isn't that high, dude. You could run a blower for a long time without having to worry. Of course you're going to want to reinforce the rods and valves, but that's just something everyone has to think about when installing a blower. I know people running 10psi turboes on 13:1 compression, daily.
If you're going to do something like that to a car, though, I don't understand why you wouldn't just buy a cheap car to begin with and completely redo it. Like an RX7 or something along those lines.
Old May 4, 2004 | 06:47 PM
Default
Here's the deal, Slick... Obviously you don't know your butt from a blower. If you run anything higher than 9.5:1 compression with a blower you're not getting the best performance from the blower and your flurting with disaster. With a turbo, depending on your intercooler efficiency, you can get away with higher compression.
Old May 4, 2004 | 06:53 PM
Default
blowers can run intercoolers, too. But intercoolers effectively increase compression by cooling the air. Everyone that runs a blower not from the factory is flirting with disaster... heck, you're flirting with disaster by sitting on 15.7 gallons of gasoline coursing through a 4000*F engine hurling 3 feet from oncoming traffic that would equal the force of 140mph upon collision. Give me a break. It may not be 'optimum' but that's hardly the point. I'm pretty sure that this Karmann built German engine is stronger than a Honda B16A 4-cylinder.
Old May 4, 2004 | 06:56 PM
Default
blowers can run intercoolers, too. But intercoolers effectively increase compression by cooling the air. Everyone that runs a blower not from the factory is flirting with disaster... heck, you're flirting with disaster by sitting on 15.7 gallons of gasoline coursing through a 4000*F engine. Give me a break.
A full blower with an intercooler.... I wouldn't even use an intercooler with a Paxton. You truly are an idiot. I'm sorry but I have to call it the way I see it. You really don't know your butt from a super-charger!
Old May 4, 2004 | 06:57 PM
Default
That really isn't as clever as you think it is.
Old May 4, 2004 | 07:49 PM
Heb80's Avatar
Default
Now this is what i call entertainment... we need better names other than "slick", "dude", and "idiot" though, but I suppose we should keep it G rated. You could always continue it thru private messages... just be sure to CC me on it though :lol:
Old May 4, 2004 | 08:05 PM
Default
Too funny :lol: :lol: :lol:
Old May 5, 2004 | 03:09 AM
SeaXfire's Avatar
Default
The SRT-6 is intercooled. Same with the AMG SLK320.
The intercooling is actually to prevent detonation, by cooling the intake air after the compressor, or turbo, is done with the incoming air.
Whether the compression takes place in the pistons or in the blower/turbo, it's the temperature which will cause detonation.
Old May 5, 2004 | 11:20 AM
BobaFettm's Avatar
Default
http://www.bath.ac.uk/~ccsshb/12cyl/
someone wanta mod that into the Xfire? .. i bet it would be fast
Old May 5, 2004 | 09:37 PM
David Burns's Avatar
Default
i think a 300 TON crankshaft would be a little much... no WONDER it has 102000 hp :!: 8) :!:
Old May 5, 2004 | 10:29 PM
AirData's Avatar
Default
I think a 6 cylinder would do it
Old May 6, 2004 | 01:24 AM
BobaFettm's Avatar
Default
I bet it could beat a Z4 and no one would ***** about it not being able to
