new rims...will tire pressure sensory system still work?
Old May 4, 2004 | 06:03 PM
tony1p's Avatar
Default new rims...will tire pressure sensory system still work?
sup everyone,
just wanted to ask those who have installed aftermarket rims if the tire pressure sensory system still works with the aftermarket rims. I know that some aftermarket rims are designed specifically for tps systems; just wondering if i get my racing hart rims that the tps system will work with them.
thanks for the input... :lol:
Old May 4, 2004 | 11:15 PM
jsisabella's Avatar
Default
It all depends if the inflators from your original wheels will fit on the new wheels.
The TPM inflators are a quite a bit larger than regular valve stems.
If you need to know what they look like, I can take a picture of a spare I have and post it for you.
What kind of wheels did you buy?
Old May 5, 2004 | 04:10 PM
Jamikest's Avatar
Default
DCs stance is very simple... Do not use the TP sensors on any rims other that DC rims. Simple liability issue obviously. So.. the question is: Will they fit? If you can fit the sensors, and be careful seating the tire, all should be well.
Old May 5, 2004 | 05:19 PM
James Sonne's Avatar
Default
As long as the new tires take the same pressure as the stock tires, right?
Old May 6, 2004 | 04:29 PM
Jamikest's Avatar
Default
Stock tires can hold 44 psi I beleive. The sensors are not intended to run at this level of pressure- the manufactures suggested tire inflation is much lower.
Old May 6, 2004 | 04:46 PM
Default
Yeah, well my tires can hold 54psi. That's the maximum level before they explode. I'm just saying, the tire pressure sensor probably senses pressure and if it's out of spec of a hardcoded level then it will go off. Every tire has a different psi level, so the sensor probably won't work for every kind of tire or rim regardless of whether or not it physically fits.
Old May 6, 2004 | 06:06 PM
WesMichaels's Avatar
Default
Where do you come up with this stuff..... There's not a tire on the market for this car that will not play with the TPM. James.... go play with your acura and quit making dumb statements... Please!!! I let most go but this one is just to dumb to ignore.:?
If your tire has "max pressure 54 psi" on it that means that 54 psi is the highest pressure you can safely use. It's not going to explode if you put 55 psi in it.
Old May 6, 2004 | 06:39 PM
x'ed's Avatar
Default
hehehe you just got bitchslapped. i think people like sonne just like posting false information on different forums. troll, there on every forum.
Old May 6, 2004 | 09:37 PM
Default
It's a technique that those of us proficient in English use known as hyperbole ...
:roll:
Old May 7, 2004 | 02:24 AM
Cyril Baldwin's Avatar
Default
I found a site for Crossfire wheels
http://www.ronalusa.com/cars/chry_crossfire.html
Old May 7, 2004 | 03:32 AM
x'ed's Avatar
Default
wow, you used proficient and hyperbole in the same sentence. im sure you've now impressed everyone, really changed "their" minds about you.
Old May 7, 2004 | 09:25 AM
Default
It was a joke on that guy with the crouching dog avatar. I called him out for making fun of Hyundai, he said he was just using hyperbole. Clue in.
Cyril, R-28, R-38, and R-39 all look pretty good on the Crossfire. Good link.
Old May 7, 2004 | 09:33 AM
jsisabella's Avatar
Default
Back to the topic:
Tony:
I apologize for not getting the pictures of the TPM sensors I promised posted to my album. Things have been wild at work.
I took the pictures. I will get them posted tonight!
Old May 7, 2004 | 12:09 PM
tony1p's Avatar
Default no prob
...thanks to the guys who've provided insightful input...and thanks for the pics too jsisabella, i appreciate the help
Old May 8, 2004 | 12:48 AM
jsisabella's Avatar
Default
tony:
I posted 2 pictures in my album
The ruler taped to the bottom of the sensor is to give it some scale....
Hope this help!
Old May 8, 2004 | 01:25 AM
Trick's Avatar
Default English 101: Lesson 2
...and our word for the day today, students, is "plagiarism." :P
Old May 8, 2004 | 02:43 AM
AZ Outlaws's Avatar
Default
Originally Posted by jsisabella
tony:I posted 2 pictures in my album. The ruler taped to the bottom of the sensor is to give it some scale.... Hope this help!
What's with the "Scotch" tape???? Real men use "Duct" tape.... :P :wink: :P
Old May 8, 2004 | 09:10 AM
Default Re: English 101: Lesson 2
What is originality? Plagiarism unrecognized. (Inge)
Old May 9, 2004 | 12:29 AM
jsisabella's Avatar
Default
AZ:
Of course I would have used Duct tape, but I wanted poor tony to be able to see the sensor!!!!
:lol:
Old May 9, 2004 | 02:21 AM
Default
Scotch is reserved after a Crossfire cruise at night
Kodebuster
Nov 5, 2020 04:06 PM
tom2112
Dec 1, 2015 09:02 AM
Rusty475
Jul 13, 2015 10:03 AM
bdh
Jul 9, 2015 09:40 AM
Blackout317
Jul 7, 2015 08:38 PM
