eyebrow lights again?
Old Mar 9, 2011 | 07:30 PM
green-ghost's Avatar
Default eyebrow lights again?
I got these from superbrights. They have built resistors and diodes to protect against reverse polarity but are they going to set off my light-out idiot light? They dont look to be like the can bus ones
Super Bright LEDs - Miniature Wedge Base Bulbs
I got the one LED wide angle ones
Old Mar 9, 2011 | 09:23 PM
Erichenderson02's Avatar
Default Re: eyebrow lights again?
Just to clarify....you're talking about the Parking Lights right? The tiny bulbs in the upper corners of the headlight housing?
If so then...
I have an '05 Base N/A Coupe and replaced my parking light bulbs with the 6 LED 35° Miniature 194 style Wedge Bulbs (In Ultraviolet Light color ) and have had ZERO issues with idiot lights coming on.
That being said...I'm not even sure my car has idiot lights (other than the low fuel light), but you shouldn't have an issue.
Feel free to PM me if you have more questions.
Regards,
Eric
Old Mar 9, 2011 | 10:37 PM
bmorgan's Avatar
Here are the ones that I have on mine. They are a bit pricy at $25 for a pair, but they look great, and no worries about error codes.
https://store.ijdmtoy.com/ProductDet...Free_T10_SKU26
Old Mar 9, 2011 | 11:37 PM
JHM2K's Avatar
I may have to look into these...
Old Mar 10, 2011 | 06:00 AM
yeah, I was being cheep and trying to go with superbrights as Boilerup (Ithink) told me they are better than the cheeper factorykiss brand; which BTW didnt seem to have them as far as I can tell.
If they do throw a code then I'll just pup them in the map lights...only $7 total for them
yes eyebrow lights. Base coupes dont have the lightbulb out in their dash, mines a limited
Old Mar 10, 2011 | 12:13 PM
They are going to throw a code, I have them in my car.
Old Mar 10, 2011 | 05:48 PM
I just might join the black tape club
Old Mar 11, 2011 | 05:50 AM
2 Car Bulbs CAN-BUS T10 3-LED SMD White Turn/Tail Light - eBay (item 220730194817 end time Mar-26-11 21:45:07 PDT)
I got these just to try, went with 3 smd cause I wanted to make sure they fit.
Old Mar 11, 2011 | 08:58 AM
LOL, I just live with the light - for now. I have nearly every single bulb inside and out converted to LEDs and it gives the car such a clean look that I can live with a small light on the dash (and it is only on when you have the lights turned on). The other nice thing is whan you have all HIDs and LEDs, you can leave your lights on for extended times (car shows) and not have to worry about draining a battery since they draw so much less than traditional bulbs....
Old Mar 11, 2011 | 09:40 AM
Cydetrak's Avatar
I grabbed these on E-bay and they look and work great no error light.
http://cgi.ebay.ca/8smd-Canbus-Error...item3f04078ee6
Sean
Old Mar 11, 2011 | 05:16 PM
Sheldon's Avatar
I grabbed mine of a BMW website... I don't know if they work because I can't get my stock bulbs out D:
ordered a pair of 45* and 90* needle nose to see if they help.
Old Mar 11, 2011 | 08:59 PM
Sheldon's Avatar
Well I got one bulb out and replaced tonight before I lost the sun. Looks great, + no error! The other bulb is like sealed in there. I guess I will try some WD40?
Anyone know of LED fog lights that will match the look? I don't care about light output, HID headlights will cover that. I just want the hyperwhite look.
Old Mar 11, 2011 | 09:21 PM
Sheldon, the fog lights are 9006 bulbs. There are lots of led lights in that application. Ive found that SMDs are superior to old LEDs. SMDs have the little yellow square wafer instead of a bulb and put out intense light.
Try www.Factorykiss.com sure its china and sketchy but their customer service is awsome
Old Mar 12, 2011 | 03:55 PM
Sheldon's Avatar
Cool I'll check it out, I assume they will need a resistor as well?
Also I finally got both my eyelids in this morning
Old Mar 12, 2011 | 09:49 PM
no resistor needed. any can bus type bulb is error free. the link will take you to their canbus bulbs. you will notice a small square thing on the bulb (resistor?) aside from the SMD.
I got their 36mm festoon canbus lights for my license plate light, heres a pic of the difference between stock and SMD
Old Mar 12, 2011 | 10:28 PM
As a highly trained law enforcement officer, I appreciate your concern for me being able to read your license plate number....lol
Old Mar 12, 2011 | 10:34 PM
LOL..as a retired military cop I just want to do what I can for my badge brothers! BTW Im working on a switch that cuts power to my license plate and tail lights...:P
Old Mar 13, 2011 | 12:40 AM
Rear panel black out... niiiice.
Old Mar 18, 2011 | 06:51 AM
3 smd, t10 canbus for 9.99 free shipping
ended up with these from factorykiss..very good quality and got them in 2weeks (china) one smd points straight ahead and the other 2 shine upside and downside filling the eyebrow area with a soft white very light blue light
AND YES THOSE SOCKETS WERE A PITA TO GET OUT. GLAD I HAVE LITTLE HANDS TO GET SPOTS LIKE THAT...UGH
Pooly
Old Mar 18, 2011 | 10:59 AM
I find that a pair of angled needle nose pliers works the best. I chewed the little ribs off the piece while carelessly twisting a few times, but if you grip it firmly and do short, 1/4 inch turns, you can get them off pretty easily.
