Headlight assembly
Old May 11, 2011 | 04:56 PM
gtrguy's Avatar
Default Headlight assembly
How hard is it to replace the passenger headlight assembly? Is removing the bumper necessary?
Thanks
Old Aug 2, 2012 | 08:40 AM
BP11's Avatar
Default Re: Headlight assembly
No removing the bumper is not necessary, I just replaced mine last night. The easiest way I came up with is take the tire off. Remove the inner plastic wheel well cover and if you jack it up you can get under it from there and see all of the bolts on the lower side of the headlight. 4 screws total. You will have to take off the grille to allow wiggle room for the headlight to come out and with some patience you can put it back in no time. Took about 2 hours total to do going very slowly but if I had to do it again I could probably do it in 30 min or less. Very very simple considering some people swear that you have to take off the bumper which is not the case.
Old Aug 2, 2012 | 10:40 AM
Agree with all above, one other hint : remove the 2 'adjuster bolts' ( the ones that the bottom 2 bolts go through ). This will give you a bit more clearance and make it much easier.
After putting the assembly back in, just start both adjuster bolts, secure the unit with the 2 upper bolts, then screw in the adjusters until they just touch the mounting brackets, secure the 2 bottom bolts.
O O O !!!! I forgot - make sure you put the parking light back in before you mount the assembly ........
( if you are lazy and a bit lucky, you can do it without removing the wheel :
1. the lower inside bolt can be accessed from inside. ( remove the overflow tank for access )
2. the lower outside bolt can be accessed through the side marker light hole.
smfrycruzr
Jul 17, 2023 05:33 PM
4drturbo
21
Nov 12, 2018 04:50 PM
4drturbo
Oct 2, 2015 12:58 PM
stlas69
Sep 14, 2015 06:45 PM
jaesa
Sep 7, 2015 01:50 PM
