Alarm Issue - Opinion
Old May 23, 2011 | 12:54 AM
simmie777's Avatar
Default Alarm Issue - Opinion
Hi all,
Like many others before me I've had alarm issues with my crossfire.
After reading almost all the threads on here, I've changed key fob, car batteries and sirens.
Even after replacing all the components I haven't had much luck resolving the issue and my alarm was still going off randomly everyday at work at least once or twice a day. (I have resisted taking it to the dealership for a variety of reasons)
I've noticed something though....during the summer months it went off almost everyday without fail! Now the weather is cooler, I have not had one false alarm!!! WTH???
Situation details:
- The car is parked is an open air car park exposed to all the elements during the day.
- The car has never had a false alarm whilst it has been parked in my garage.
My question-
Should the weather effect the alarm function???
Any other suggestions are welcome.
Thanks,
Michael
Old May 23, 2011 | 02:27 AM
jmk41's Avatar
Default Re: Alarm Issue - Opinion
Originally Posted by simmie777
Hi all,
Situation details:
My question-
Thanks,
Michael
Search will help you on this one, mine seemed to only go off when its damp out or the humidity is really high to fix mine i re-soldered the alarm module or what ever the h311 it is located in the trunk under the foam and this seemed to work! As for right now tho just pull the fuse to keep it from going off the only down side is you will lose interior dome lights and your key wont lock the passenger door you have to manually lock it and the hatch doesn't lock but no one other than an xf owner knows where the handle is for it anyway,,,
Old May 23, 2011 | 05:06 AM
simmie777's Avatar
Thanks for the reply, yeh I was doing the fuse trick throughout the summer. I will give the resoldering option a try and see if that works.
Old May 26, 2011 | 06:53 PM
rekcah's Avatar
central locking pump/security system module in the trunk under the styrofoam. This module can mess with alarm, siren, lights, locks. The placement of this module is bad. Water can leak into the trunk from multiple places and get to the connectors of this module.
Some Mercedes have the same problem.
Old May 27, 2011 | 10:15 AM
jmk41's Avatar
I wonder if any one has moved this module before? If the location of it is bad why not move it?
Old May 27, 2011 | 10:38 AM
rekcah's Avatar
It can be moved. Just need to find another place, extend the wiring and air hoses.
Or fix any possible leaks; the gas filler gasket and rear spoiler were the spots on my XF. What the Mercedes dealer does to fix the problem is turn the unit upside down and put it in a bag. There is is a kit for that, but probably won't work on the XF, because in the Mercedes its mounted vertically whereas the XF its horizontal.
Old May 27, 2011 | 12:34 PM
jmk41's Avatar
In theory nothing you do to seal anything will work because of the vents in the hatch moisture can still get in. I like the idea of the bag tho! I will be posting my fix if and when it gives out again...
Old May 31, 2011 | 12:30 AM
ZORRO's Avatar
Just pull the plug on the siren and be done with it. Everything else still works.
Old May 31, 2011 | 01:07 AM
simmie777's Avatar
Wont that set off the alarm, as it has its own powersource?
Old May 31, 2011 | 02:27 AM
ZORRO's Avatar
Pulled the wire on mine last spring. The alarm quit going off and has never been a problem since. when I say everything still works, even the little red light on the dash that tells people the alarm is on still blinks. It's not but who could tell?
pioneer4x4
Mar 18, 2021 02:17 PM
Reliableron
Oct 17, 2015 10:19 PM
Mackel
Oct 16, 2015 09:03 AM
bobbie
Sep 12, 2015 12:49 PM
MickeyNasty
Sep 6, 2015 08:29 PM
