Spark Plugs and Throttle Body
Old Jun 2, 2011 | 05:45 AM
Phil's Avatar
Default Spark Plugs and Throttle Body
Guys,
My 2004 Cupe has about 95,000 km on it. My dealer is saying that the spark plugs should be replaced (12 plugs) at a cost of $514.00. As well, he recommends "tuning" the throttle body, as part of a "Tune Up". The only real maintenance that i've done is oil changes. Does this make sense?
Old Jun 2, 2011 | 06:07 AM
BLACKSRT-6's Avatar
Default Re: Spark Plugs and Throttle Body
The plugs should be done but $500 is an amazing dealership rip off. If you have any mechanical ability at all, you can change them your self in a couple hours and yes there are 12 plugs. Cleaning the throttle body is just a rag and a $5 spray can of throttle cleaner from any parts store. If you can't do the work yourself, call around your area and get some quotes for a tune up (ask what is included in the tune up) should cover both the plugs and thottle body for 1/2 what the dealership is stating.
Old Jun 2, 2011 | 06:39 AM
Phil's Avatar
Thanks ... that's what I thought.
P...
Old Jun 2, 2011 | 06:41 AM
joejones's Avatar
Should the ignition cables be replaced as well?
Old Jun 2, 2011 | 08:52 AM
MikeR's Avatar
Not unless your having issues with them.... or just want to
Old Jun 2, 2011 | 01:45 PM
waldig's Avatar
Talking Re: Spark Plugs and Throttle Body
Woodys old plug trick #17.
Use a 6" section of rubber 3/8 Id fuel line or similar tubing to loosen the plugs and start the new ones AFTER you break them loose. THe rubber hose covers the top of the plug and grasps it so you can loosen and pull // install new plug with a minimum of hassel and tears.
#18 Always add thread anti seeze compound on bolts especially plugs when doing reassembly, youll love the results next time.
ENJOY< Woody
Old Jun 2, 2011 | 03:22 PM
Phil's Avatar
Thanks for the advice.
Old Jun 2, 2011 | 03:24 PM
deltacrossfirebob's Avatar
if you are going to do it..do it right.
get rob a needswings.com
get the ngk plugs from him along with the magnor wires.
best way to go.
also put in k&n air filters.
you will like the improvement.
bob
Sterling57
Apr 11, 2016 06:11 PM
cjw
Oct 26, 2015 10:26 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 28, 2015 07:40 PM
cjw
Sep 27, 2015 10:22 AM
