CRACKED a/c condensor
Old Jun 8, 2011 | 08:43 PM
crossfire6412's Avatar
Default CRACKED a/c condensor
So my ac condensor crack about a half inch away from the fitting to the compressor line. And chrysler wants $800 for a new one. Any one have any ideas? The thin tubing looks risky to tig weld and. I doubt jbweld will hold the psi
Old Jun 8, 2011 | 08:46 PM
Default Re: CRACKED ac condensor
Check with your local radiator shop to price a new aftermarket. James
Old Jun 8, 2011 | 08:54 PM
I just checked the yellow pages. Lol don't see any radiator shops any where near here
Old Jun 8, 2011 | 08:57 PM
DODGE CROSSFIRE 04-05 A/C CONDENSER CAR AC *NEW* | eBay
I would call them and see if a Dodge Crossfire condenser will interchange with a Chrysler Crossfire condenser
Old Jun 9, 2011 | 04:58 AM
magredvet's Avatar
Default Re: CRACKED a/c condensor
Replaced mine last year with the one from an 03 SLK32, which you can find aftermarket for about $180. Had a hard time convincing the AC shop that it would work, but they're exactly the same, and even carry the same (aftermarket) part number.
If you need it, I can look at the car tonight, and get the part number for a cross reference ?
Old Jun 11, 2011 | 01:00 PM
Thanks for the ideas. I brought the condenser to a local race car shop and had them weld the crack and pressure test it for $30 bucks. The way the lower lines are clamped together im sure more ppl are going to have this problem .... I would def suggest drilling the rivit out on the clamp and just leave it off.
Old Jun 11, 2011 | 01:19 PM
Can this be seen from the bottom or top? I will take a look when I can.
Old Jun 11, 2011 | 02:24 PM
The two clamped hard lines are at the bottom on the condensor on the left side. I don't think you can see it from up top.if you take off the fog light covet you can prob see it with out tearing the car apart
Valk
Jul 12, 2021 09:49 PM
UNDER PSI
Nov 1, 2015 09:39 PM
debradegiovanni
Sep 27, 2015 09:39 AM
atdavis2
Sep 21, 2015 01:25 PM
BEATv1
Sep 10, 2015 12:58 PM
