Is this a Cold or Hot Air Intake?
Old Jun 13, 2011 | 09:08 PM
Chris L.'s Avatar
Default Is this a Cold or Hot Air Intake?
Old Jun 13, 2011 | 09:11 PM
Default Re: Is this a Cold or Hot Air Intake?
It is sucking air in after the air went through a hot radiator.
Old Jun 13, 2011 | 09:32 PM
bmorgan's Avatar
definitely an HAI.
Old Jun 14, 2011 | 05:28 PM
DSC_5344.jpgCold Air Intake
Old Jun 15, 2011 | 12:59 AM
Mimi05SRT6's Avatar
It's a WAI....Warm Air Intake...
Old Jun 15, 2011 | 02:03 PM
goodgenes79's Avatar
It looks like it hasn't done anything but replace the stock tubes that ran beside the radiator, with filters behind the radiator. I would think this would be worse than stock due to hotter air. Maybe replacing stock filters with these cones provide a slight improvement but placement henders it. Just my opinion but it doesn't seem worth the time or money. Cheers
Old Jun 15, 2011 | 06:52 PM
mdaniels4's Avatar
Ditto on Mimi. Bigger tubes better cooler air. Behind the radiator a bit warmer. Extend even rubber tubes in front and you'll get cooler air. mine are awesome for the NA. As much as this one will ever see. the next will be an 8 at least then we'll talk from there. Thanks Beaner
Old Jun 16, 2011 | 01:45 PM
jmk41's Avatar
Originally Posted by oledoc2u
Cold Air Intake
Doc how did you manage to do this? What did you use inorder to pass through the radiator mount or what ever that large piece of metal is called?
Old Jun 16, 2011 | 03:34 PM
it is a Needswings dual cai...it comes with everything you need for install...there are plastic supports on either side of the radiator support frame that have to be removed...read about the kit on www.needswings.com I am broke down in Coldwater MI right now...so hangin' out in the Holiday Inn Express....lol....
Old Jun 16, 2011 | 08:06 PM
itsky's Avatar
Hopefully not the car?
Old Jun 16, 2011 | 08:27 PM
nope, big rig......turbo gone, innercooler leaking....nothing a day and $5K won't fix....lol
Old Jun 16, 2011 | 10:28 PM
Larry Hitze's Avatar
Hell Doc, after a night at the Holiday Inn Express you ought to be able to fix anything!
nataliefs
Oct 5, 2015 01:03 PM
Ralph289
Sep 21, 2015 09:34 PM
Idrenak
Sep 19, 2015 08:17 PM
tritongreen
Sep 18, 2015 07:32 AM
waldig
Sep 17, 2015 10:35 AM
