HELP I need a headlight connector
Old Jul 10, 2011 | 11:02 AM
crossfire6412's Avatar
Default HELP I need a headlight connector
The plug for.my head light has corroded pins that basically are not there any more they are corroded so bad. Does any one have a wrecked car with this part? Its the main harness side (male) connector to the headlight
Old Jul 10, 2011 | 11:08 AM
Default Re: HELP i need a headlight connector
Old Jul 10, 2011 | 11:56 AM
www.wyckoffchryslerparts.com He's on vacation this week, but the site will still take your order. He's a private parts supplier now. Usually has access to all Chrysler parts for our cars. Should be quick shipping for you.
Old Jul 10, 2011 | 11:57 AM
Originally Posted by crossfire6412
Basic Sex Ed 101 would make that the female plug, but these days who knows. Nothing wrong with that though of course.
Old Jul 20, 2011 | 11:51 PM
Default Re: HELP I need a headlight connector
Yea my bad ....female side connection. If any one has any broken headlights though I could also use the wiring male side connection
Old Jul 21, 2011 | 07:26 AM
This could be used, cut of one end and solder the new plug up to the existing wires.
H7 HEADLIGHT WIRE HARNESS 2004-2008 CHRYSLER CROSSFIRE | eBay
Old Jul 26, 2011 | 06:04 PM
I don't need the plug to the bulb. I need the actual plug to the back of the head light from the wire harness ( it runs all the lights in the head light. High&low beams as well as the turn signal
Old Jul 31, 2011 | 11:45 PM
Schrudds's Avatar
I have the same problem. I have been driving for about 3 months without my left front low beam. If you locate a (part number 05102615aa) headlamp connector please let me know. I went to a MB dealer and bought their headlamp connector however it did not work.
Shrudds
Old Sep 8, 2011 | 07:59 PM
Hey sorry to get to this thread so late. After searching and searching the shelfs at my local dealership and finding NOTHING for the crossfire I found that the headlight plug for dodge/ mercedes sprinters work.(they call it an insulator) the part number is 1-05143205aa this is an empty insulator you still need the pins for it. The pins originally used on the crossfire are not available how ever the dealership electrical repairs kit ( every dodge dealer has one) has pins that are very close and call be used
Old Sep 8, 2011 | 08:08 PM
Old Sep 8, 2011 | 08:35 PM
Larry Hitze's Avatar
If you aare refering to the clips that hold the headlight in you might be able to get one from forum member Maxchicon ashe is making the from a pattern.
Old Sep 9, 2011 | 06:27 AM
maxcichon's Avatar
Larry, I think he is referring to the electrical pins inside the shell he shows in the picture.
But thanks!
Old Sep 9, 2011 | 09:49 AM
But thanks!
Sorry, my mistake.
Old Oct 19, 2017 | 10:23 AM
lacannow's Avatar
I'm joining this thread in the hopes of finding a solution to the 05143205AA issue. Have 04 model with new headlight assembly but the pins are corroded on the above part. Where can I get?
syfi
Mar 28, 2026 04:14 PM
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
ala_xfire
Sep 28, 2015 05:51 PM
bobbie
Sep 12, 2015 12:49 PM
