why won't my subs work in my car
Old Aug 1, 2011 | 05:36 PM
mikeandyance's Avatar
Default why won't my subs work in my car
how can i hard wire the rca imputs to the amp its self and will this solve my problem have a alpine 9886 everything is connected right but no wires for the subs besides the rcas that come from the main harness
Old Aug 1, 2011 | 05:46 PM
jmk41's Avatar
Default Re: why wont my subbs work in my car
The easiest thing to do is by pass the factory amp and install an aftermarket one. Its a bit more wiring but you'll find it to be pretty easy and then you'll know what you have when your finished. The factory amp however is of pretty good quality and maybe worth the time to make it work. This wasn't the case for me; I ran a second set of speaker wires and power wires so i could easily remove the system like I ended up doing due to space limitations when traveling.
Old Aug 1, 2011 | 05:55 PM
jmk41's Avatar
You are talking about a sub box for in the hatch right and not the stock "subs" behind the seats right?
Old Aug 1, 2011 | 06:06 PM
how do you hardline the subs to the amp what wires do i splice so i can turn it into an rca wire
Old Aug 1, 2011 | 06:51 PM
jmk41's Avatar
Wiring A Car Amplifier i hope this helps
pay a mind to the amp turn on wire!!! This caused me headaches
Old Aug 1, 2011 | 08:23 PM
redeagle's Avatar
@mikeandyance - I read your question to mean you wish to use the sub outputs from your new Alpine HU to connect to the stock "subs" (rear speakers) If this is what you want to do you will need to splice on RCA connectors to the wire harness. I would splice on 4 RCA connectors -
Splice RCA jacks to the harness wires that go to the front and rear speakers (rear speakers are the "subs" in the Crossfire) - then plug them into the HU's Pre-Amp Front Speaker RCAs and the SubWoofer RCAs
Your HU has enough pre-amp voltage (4 volts) for the factory amp to do a decent job. This should give you a cleaner sound by bypassing the HU's built in amp.
Here is a diagram of the Crossfire Wire Harness:
2004-2007 Chrysler Crossfire with Infinity Wiring Information
Hope that helps
redeagle's Avatar
Splice RCA jacks to the harnes wires that go to the front and rear speakers (rear speakers are the "subs" in the Crossfire) - then plug them into the HU's Pre-Amp Front Speaker RCAs and the SubWoofer RCAs
Hope that helps
Old Sep 17, 2011 | 06:02 PM
k..thanks now i got a 12in sub 400wtt..i want the hu to power the doors and the amp for the sub...install ideas?
ingsoc39
Jul 7, 2022 04:25 PM
foxy1305
U.K.
Jan 1, 2020 11:41 AM
mhajek18
110
Sep 6, 2019 01:04 PM
carmax
Jun 18, 2015 01:30 PM
brian peluso
Aug 22, 2003 12:22 PM
