Rear Brake lights on and dont shut off
Old Aug 23, 2011 | 05:39 PM
Hipower's Avatar
Default Rear Brake lights on and dont shut off
Hello I am new to the forum, I need some assistance :
My rear tail lights and cruise control are not working properly, The taillights stay on the entire time the car is running, when i push the brake pedal the tail lights blink but remain on . I checked the fuse box, fuse is ok. Any ideas ? thanks.
Old Aug 23, 2011 | 05:46 PM
Default Re: Rear Brake lights on and dont shut off
Originally Posted by Hipower
New the forum I have and 04 Crossfire, i need help, My rear tail lights and cruise control are not working properly, The taillights stay on the entire time the car is running, when i push the brake pedal the tail lights blink but remain on . I checked the fuse box, fuse is ok. Any ideas ? thanks.
Check the brake switch on the brake pedal.
Start on the simple stuff first.
Old Aug 23, 2011 | 06:05 PM
Hipower's Avatar
went to check , a no go . i also checked fuse box no fuses blown.
Old Aug 23, 2011 | 11:42 PM
Kodebuster's Avatar
When you say no-go, does that mean you confirmed the Brake Pedal Switch to be operating correctly, like with a voltmeter...???
Or possibly just a visual check to ensure it phsically engages by depressing the Pedal...???
Old Aug 24, 2011 | 05:10 AM
Hipower's Avatar
I couldnt find the brake pedal " switch" , where is it located, i felt all around the brake pedal. Thanks.
Old Aug 24, 2011 | 08:59 AM
Kodebuster's Avatar
I have yet to be in this area personally, but according to the Service Manual (page 5-53), you need to remove the Panel sitting right above the pedals.
You should see the Stop Lamp Connector, which is for the Stop Lamp Switch.
It's the connector or Switch that should be of interest...
If anyone has been here, I'm sure they'll chime in...
Old Aug 26, 2011 | 12:41 PM
kc850's Avatar
Just wondering if you figured out the problem and got yours fixed yet, I have the same problem.
Old Aug 26, 2011 | 01:29 PM
Hipower's Avatar
Yes i have , it was the brake switch, it had jammed for some reason, so it wouldnt shut off nor could i use curse control. $100 to fix.
Old Aug 26, 2011 | 07:19 PM
kc850's Avatar
Thanks a bunch, did you do it yourself or take it to the dealer?
Hoppy
Dec 7, 2018 07:36 AM
Roty135
17
Oct 11, 2018 10:11 AM
axnguyen
Jul 21, 2015 11:41 AM
westonrose
Jul 14, 2015 11:25 PM
Blackout317
Jul 7, 2015 08:38 PM
