Stock head with audio input jack
Old Sep 4, 2011 | 07:49 PM
Mubassmastajoe's Avatar
Question Stock head with audio input jack
Hey all, my first time here... I recently bought a used 04 alabaster coupe and noticed it has an 8th inch jack that says "audio input", but I cannot get the radio to switch to this input, even with high levels of input. I'm fairly new to the world of car audio, especially the crossfire, but I can't seem to find a thread with a similar senario. Any help would be delightful as cd's are so "old tech"
Old Sep 4, 2011 | 09:04 PM
Default Re: Stock head with audio input jack
New development, found a switch next to drivers right knee under dash, can't get it to do anything...
Old Sep 5, 2011 | 09:00 AM
MI1XFIRE's Avatar
I have a similar set up for my ipod. With radio off, plug-in your MP3 player and flip the mystery switch. To go back to radio, flip the switch the other way and turn on radio.
On mine,I installed the switch and jack inside the center console.
Old Sep 5, 2011 | 09:11 AM
I was going to suggest you follow the wiring, but I think you might have the answer from MI1XFIRE.
JM, how's the sound quality you get from your setup?
Old Sep 5, 2011 | 09:26 AM
waldig's Avatar
Talking Re: Stock head with audio input jack
Looks like someones add on, there is no audio jack in my car or others Ive seem, Woody
Old Sep 5, 2011 | 10:21 AM
KimPossible's Avatar
Someone went Frankenstein on your audio system before you got the car. If the other suggestions don't work then you will probably have to follow the wiring. Most of the iPod docks I have seen are in the console. Good luck & congrats on the new XF.
Old Sep 5, 2011 | 10:49 AM
MI1XFIRE's Avatar
Sound quality appear better than from the OEM headunit but you have to remember that you're still going thru the stock amp and speakers. I guess anything is better than the stock radio....
Everything including volume is controlled thru the ipod.
All it consist of is a small electronic switch box that connects to the back of the radio (uses stock connectors) and powers the amp when the stock radio is turned off and and external switch is activated.
I don't know if you can still find these, it was a mercedes SLK R170 aftermarket accessory that I got from a guy that was going to offer them for the XF but not too many ppl showed interest at the time....They was a thread on here about it about 4 to 5 years ago.
Old Sep 5, 2011 | 10:07 PM
Thanks for all the help, I tried your suggestion, but no go, I can't get the switch to do anything, I'm going to follow it (wiring) and see if the switch was disconnected. I absolutely love the car, but I got to have it all working
Old Sep 6, 2011 | 05:47 PM
MI1XFIRE's Avatar
Also make sure the previous owner didn't take out the electronic unit that plugs-in at the back of the radio.
usprb1976
Apr 4, 2024 04:57 PM
minimayhem
16
Aug 23, 2016 07:47 AM
KDW4Him
Crossfire Events and Meets
15
Sep 30, 2015 08:53 PM
smokey847
Sep 15, 2015 10:47 AM
xjken
Sep 6, 2015 11:37 AM
