Emblem Removal
Old Sep 21, 2011 | 01:07 PM
Erichenderson02's Avatar
Default Emblem Removal
Hi all,
After searching many threads I was not able to find a step by step process for removing to Chrysler wings emblems.
I'm just trying to take them off, so I can prep/paint them. I tried using a heat gun and fishing line on the front, but got stuck because I couldn't figure out how to pull out the metal plug things that hold the emblem in place. Is there a special way to get these out, without breaking them off? (Because I want to replace the emblem when I am done painting it)
And for the rear emblem... are there any hidden mounting plugs? Or can I just use fishing line and the heat gun all the way?
Thanks,
Eric
Old Sep 21, 2011 | 01:55 PM
Default Re: Emblem Removal
The front one has rivet like tabs on the back, you may be able to remove them from the back when the hood is popped, not sure, never tried. PM MadMed with the CF hoods, he has taken his off, and must know how.
On the rear, you are correct, no tabs there, just heat, use some non-wax dental floss or low test fishing line, followed by some 3M wax and adhesive remover, and followup with some proper polishing, if you intend to leave it off....
Hope this helps.
Old Sep 21, 2011 | 02:33 PM
Hope this helps.
Thanks man.
Yeah when the hood is popped I can see the rivet like tabs on the underside of the hood. Just don't know how to release them without breaking them off.
And don't worry, the emblems are going back on as soon as I paint them.
Old Sep 21, 2011 | 03:07 PM
FUBU's Avatar
I have had my car disassembled to bare skin. By myself So ask me anything if needed.
The emblem in front, just peel those rings off. Always use soft plastic tool. Use hairdryer or heatgun while bending loose simultaneously.
Old Sep 21, 2011 | 05:03 PM
So the rings peel off from the emblem's "teeth"? (By teeth I mean the things that stick through the hood's mounting holes)
Or do the "teeth" come off of the emblem? Thanks for the help, clearly you can see how confused I am.
I'm like.
-Eric
Old Nov 24, 2023 | 12:47 PM
Robgauss's Avatar
You have rebadged the entire car? How did you remove the fender emblems. Looks like you have to remove the wheel and lining?
Old Nov 24, 2023 | 12:49 PM
This is a 12 year old thread, not much chance of an answer.
Old Nov 24, 2023 | 02:34 PM
I don't believe they have any badges on the fenders. Do you mean the silver strakes?
Old Nov 24, 2023 | 02:43 PM
Robgauss's Avatar
Yes indeed.
Old Nov 24, 2023 | 03:24 PM
exparamedic's Avatar
How to remove side strakes.
Old Nov 24, 2023 | 03:35 PM
Robgauss's Avatar
Thank you for this. Most appreciated.
Old Nov 24, 2023 | 04:06 PM
Just about anything you need to know can be found in a Google search or in this link.
Old Nov 24, 2023 | 04:19 PM
Robgauss's Avatar
Yes, you are right. My mistake was not using the correct terminology. Do a Google search on "Fender Badge" and you will not find this link. Do the same with strakes and you will. I did not know they were called that. Now I do. That you again.
Old Nov 27, 2023 | 06:40 AM
See the attached file. I highly recommend you download a Service Manual from the Forum The 2004, 2005, 2006 Versions are available to you. CLICK
The video in a previous post is also very good. Everyone refers to the side emblem as 'strakes'. But the Service Manual refers to them as a 'side louver''.
Old Nov 27, 2023 | 09:01 AM
Robgauss's Avatar
I love that link, it is a remarkable asset for this forum. Many thanks to 180 and pizza guy and ALL of the contributors here that make this forum what it is!
Essa5225
Oct 21, 2023 08:31 PM
cuervoacres
Dec 5, 2014 05:49 PM
Gwetoe
Feb 10, 2007 10:24 PM
rjreiser
Jul 20, 2006 04:56 PM
Cyril Baldwin
Jul 20, 2005 08:50 PM
