Headlight not adjusting...
Old Sep 25, 2011 | 04:36 PM
Pat13's Avatar
Default Headlight not adjusting...
while i was installing hid lights i was trying to adjust the passenger side light by twisting the screw and it would not adjust at all. I adjusted the driver side one with no problems, i was wondering if there something i can do to try to get it working again, it turns left and right but nothing happens
Thanks
Old Sep 25, 2011 | 06:55 PM
grip grip's Avatar
Default Re: Headlight not adjusting...
Turn the adjustment clockwise until it clicks back into the joint.
Old Sep 25, 2011 | 09:22 PM
Pat13's Avatar
Thanks ill give it a try, i did turn it for quite a while and it still didnt do anything. I did notice it was a bit harder to turn then the other headlight
Old Sep 25, 2011 | 09:50 PM
I have a spare headlight I got off the shelf and took some pics. It does appear that the adjustment shaft (with threads) must have a ball end on it. It appears that it slips inside the white piece of plastic in the pic.
I would try, as suggested to turn the **** in as far as it will go. But first try to get a mirror in there and see what is going on. Before you wind it in, you may want to be sure the ball end is lined up in the plastic proplerly or you may break it.
Old Sep 25, 2011 | 10:00 PM
Ok, here is a better pic with a larger mirror. I turned the adjustment in 5 turns before it stopped, to get a better shot of what you need to look at.
Old Sep 25, 2011 | 10:28 PM
Pat13's Avatar
Ok just to clarrify that whit plastic peice is on the inside where the thread screws into right ? that isnt the the same plastic piece that you can turn with you hand? sorry I cant picture what i need to be looking at right now, ill check tomorrow and report back
Old Sep 25, 2011 | 10:32 PM
Thanks
After installing HID's it is not required to adjust the headlights except maybe for a little tweak to get a preferred beam pattern. The headlights should be OK the way they were previously, any major beam error is the result of the HID bulbs being installed improperly.
Old Sep 25, 2011 | 10:39 PM
Yes, the white plastic piece in the pic, is on the opposite end of the adjuster shaft from the ****, inside the headlight assy.
Old Sep 28, 2011 | 09:45 PM
Pat13's Avatar
Thanks for the help, it works fine now and its adjusted right. I got a bad set of hid's and I tried to adjust them thinking it would help, it didnt. Today I bought hid simuators which I must say are really nice, the bulbs had blue film on them but the light is white, im extremely happy with them
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
gp1200x
Dec 6, 2015 12:59 PM
RacerXofFL
Sep 15, 2015 05:00 PM
