Bright lights not working - won't pass inspection
Old Oct 12, 2011 | 01:15 PM
SpeedDemon's Avatar
Default Bright lights not working - won't pass inspection
My bright lights aren't working and my car is due for an inspection this month, which I've been told the car won't pass because of the lights. Before I spend $130 getting the problem diagnosed, I was wondering if anyone could tell me what would cause this to happen. I don't believe both bulbs are out because it seems unlikely that they'd go out at the same time. I'm thinking it's a connection problem because the lights came on once after the problem started. Any ideas?
Thanks for your help.
Old Oct 12, 2011 | 02:20 PM
maxcichon's Avatar
Default Re: Bright lights not working - won't pass inspection
They are on a separate fuse and have their own relay.
Old Oct 12, 2011 | 03:20 PM
caddymike85's Avatar
I have the same problem, I've read here that its a combination of the headlight switch and turn signal stalk on the column. I've replaced the headlight switch but it didn't fix the problem now I'm looking into the turn signal stalk. You might also want to look at this thread, it lists a couple part number and has a great comment from our friend maxcichon. Good luck
https://www.crossfireforum.org/forum...eams-gone.html
Old Oct 12, 2011 | 03:42 PM
So the high beams are gone, are they now lows or are they just fog lights?
Old Oct 12, 2011 | 05:02 PM
maxcichon's Avatar
Oh, boy. Must have been in a great mood that day...
Old Oct 13, 2011 | 08:02 AM
SpeedDemon's Avatar
Thanks for the info, everyone. I'll go check out the other thread.
Old Oct 13, 2011 | 08:05 AM
SpeedDemon's Avatar
Ok, so based on what I'm reading, it seems that I'm going to have to pay for the diagnostics test because it looks like it could be a number of things. This stuff happens every year just before inspection time. Good grief.
Thanks for the help, as always everyone.
Old Oct 13, 2011 | 08:50 AM
If you look at the repair manual it will explain how to check out the Illumination Module (light switch) and it will save you money. The switch is an expensive piece of gear and for sure they will make you pay list price for it. These switches are available from wrecks on ebay and if that is the problem it will be much less expensive.
Old Oct 13, 2011 | 09:01 AM
SpeedDemon's Avatar
Hey, thanks. I'll definitely look into that.
2004_
Jul 9, 2025 12:39 AM
DaveMe
U.K.
Apr 13, 2016 03:28 AM
stlas69
Sep 3, 2015 10:28 AM
Rusty475
Jul 13, 2015 10:03 AM
Blackout317
Jul 7, 2015 08:38 PM
