Just found this switch, what is it?
Old Oct 13, 2011 | 01:07 PM
818.crossfire's Avatar
Default Just found this switch, what is it?
In the center console compartment there is a switch, what is it for? I've had my crossfire for almost 2 years and just noticed it. I searched but didn't come up with anything.
Old Oct 13, 2011 | 01:14 PM
Default Re: Just found this switch, what is it?
Your guess is as good as anyones. It is NOT OEM, whatever it is.
( maybe ejection seat ?????? )
Old Oct 13, 2011 | 01:15 PM
Sounds like fun....Ill go out and take a pic of it. Make sure im explaining where it is correctly.
Old Oct 13, 2011 | 01:19 PM
rush549's Avatar
That's the warp speed switch. Don't touch it... Oop's, there he goes!!!
Old Oct 13, 2011 | 01:21 PM
I wish it was the "FIX MY FUGGIN TRANSMISSION" button or even the "ILL SAVE YOU 5 GRAND TODAY" button
Either one would work right now.
Old Oct 13, 2011 | 01:33 PM
IBLUBYU's Avatar
If you have a roadster, it might be a switch put in by a previous owner, to turn the lights on and off on a windscreen. Windscreen may have been removed. Just sayin ...
Old Oct 13, 2011 | 01:38 PM
Now that I take a look at it, it doesn't appear to be OEM. I have an 04 na hardtop
Old Oct 13, 2011 | 01:47 PM
waldig's Avatar
Talking Re: Just found this switch, what is it?
Possibly a fuel cut off security switch or a parking light switch? Youll have to explore to see where it goes, Woody.
Old Oct 13, 2011 | 02:25 PM
Toggle the switch and check for dash lights. Only other thing you can do is trace those wires and find where they go to, that'll tell you what its for.
Old Oct 13, 2011 | 02:47 PM
Sheldon's Avatar
Valet mode for an aftermarket alarm?
Old Oct 13, 2011 | 05:15 PM
got to love secret switches.... like the others stated, need to trace the wires.. lighted wind screen could be a possibility. You can light them with a 9 volt battery, and make it switchable...
Old Oct 13, 2011 | 08:32 PM
TomStratRT's Avatar
Originally Posted by oledoc2u
...lighted wind screen could be a possibility...
Not likely, it's a coupe, not a convertible.
Old Oct 13, 2011 | 08:47 PM
Most likely or some aftermarket lights.
Old Oct 13, 2011 | 09:13 PM
JasRios85's Avatar
It could be a fm cut off switch for the radio to plug in a ipod since thats what i have and the switch looks similar...it just cuts off a frequency on a fm station so you can play your ipod threw it clearly...just check the back of the radio one day and see if you see a cut off box there...the one i have is a scosche fm modulator and the switch looks similar
downwardspiral's Avatar
Could be for a nitrous kit
Old Oct 13, 2011 | 10:14 PM
itsky's Avatar
I suggest that you make sure that you are at highway speed, hit the switch and let us know what happens. Seriously, it surely doesn't look OEM. Your guess is as good as mine.
Old Oct 13, 2011 | 10:47 PM
DavidOv54367's Avatar
fuel cut off switch in case it gets stolen??
Old Oct 14, 2011 | 03:06 AM
I stand corrected...maybe "mood" lighting then...lol
Old Oct 14, 2011 | 05:19 PM
MikeR's Avatar
You CAN put a windscreen in a coupe.....makes a good divider and place for graphic art....
Old Nov 9, 2011 | 12:10 PM
srt666's Avatar
Does it fit?
