HID Focus Spot
Old Nov 21, 2011 | 05:27 PM
austinboyette's Avatar
Angry HID Focus Spot
Ok, I have 5,000K HID's in my Low Beams. My Passenger side has the bright focus spot in the middle of the beam, but my driver side doesn't, the bulbs ARE seated correctly. I've checked about 10 times now, they also dont seem to align very well when pointing on the garage. I need help because its driving me nuts, because I like everything to be just right.
Old Nov 21, 2011 | 05:41 PM
hcarter's Avatar
Default Re: HID Focus Spot
Do a search on headlight adjustment and you will find a lot of help with your light problem...Good luck.
Old Nov 21, 2011 | 07:58 PM
I've aimed them and everything. My driver side is not getting a very bright focus spot, it's very dim. I didn't know if it has something to do with the headlight or the bulb.
Old Nov 21, 2011 | 08:01 PM
jonnyangel04's Avatar
100% can tell you they are not seated properly, I know from having the same expirence. its so hard to get in there, that you think you have them seated properly, they are not.
Old Nov 21, 2011 | 08:13 PM
tighed1's Avatar
I feel your frustration! Just put HID's the the NA and the passenger side is fine (excpt for slight flickering) the driver side is some sort of oval pattern that sucks! I also have checked the alinement a zillion times and it's STILL jacked!
BTW the drive side flickers BAD. Looks like one of those motorcycle headlights that flash for more visibility.
Old Nov 21, 2011 | 09:48 PM
maxcichon's Avatar
If you have an oval beam pattern, it is definitely not seated properly.
You can unclip the clip (?) and rotate/adjust it when the bulb is on-it won't get too hot. This is the easiest way to do it. The correct position is very subtle. It only has to be off a scoshe and it will give you an oval. Try it-it works!
KDW4Him
Crossfire Events and Meets
15
Sep 30, 2015 08:53 PM
MiamiTVR
Other Cars Etc
Sep 29, 2015 05:27 PM
JEFASOLD
Sep 28, 2015 12:10 PM
AlbertFattal
Sep 24, 2015 05:03 AM
RacerXofFL
Sep 15, 2015 05:00 PM
