Replacing turn signal light
Old Jan 13, 2012 | 01:19 PM
TimothyGeorge's Avatar
Default Replacing turn signal light
My left turn signal was clicking rather fast so I changed it out. The light continues to click quickly on occasion. It works when I first start the car, but after a few miles up the road it goes back to not working. What could this problem be?
Old Jan 13, 2012 | 02:34 PM
Default Re: Replacing turn signal light
any idea if it is the front or rear TS light ?
Probably the front, the plastic bulb holder is known to have contact issue with the headlight housing.
Pencil eraser the contact points on the bulb holder, and in the housing, if you can get to them.
Try some diaelectic grease also.
Old Jan 13, 2012 | 02:53 PM
maxcichon's Avatar
Yep. That's what I would do!
Old Jan 13, 2012 | 03:31 PM
thank you, I will try that and see how it goes... I just hate when something goes wrong on the car, I feel as if I am not representing the car well...lol.
Old Jan 13, 2012 | 04:39 PM
maxcichon's Avatar
Try adjusting (turning) the lamp holder while it is ON. This will give us more info to help you.
Old Jan 14, 2012 | 05:56 AM
Clivedrive's Avatar
Had that problem about a month ago, agree with all those suggestions but what did it for me was to change one side plastic bulb holder with the other..seemed to work..good luck
Old Sep 18, 2019 | 04:24 PM
arletd@sbcglobal.net's Avatar
Talking Re: Replacing turn signal light
Original owner '05 Xfire 59K. Have fixed sticking key issue as per Paul with his video after dealership tried 2x replacing tumbler. Now have right front turn signal flashing quickly and no light in right rear. Replaced the bulb, still not working. Put replacement bulb in left turn socket and works fine so some kind of wiring/connector problem? Multimeter (v) shows no current in bulb socket or in black multiwire connector for this socket. Fuse on left side of dash pulled, cleaned with no change. I know wiring is problematic with this car. Perhaps wire disconnected under dash during my adventure. Really reluctant to remove dash again. Any ideas would be appreciated.
Roty135
17
Oct 11, 2018 10:11 AM
jgreen
106
Sep 18, 2017 11:46 PM
axnguyen
Jul 21, 2015 11:41 AM
Adrian_X
Jul 12, 2015 11:05 PM
joethejeweler
Jul 7, 2015 08:58 PM
