dual cai vs cai
Old Jul 30, 2012 | 06:05 PM
Jackerman's Avatar
Default dual cai vs cai
Was searching the forum for a DIY and some more info on the topic but i didn't really see much or I didn't search long enough
So I'm Just wondering which provides more gains ? A single Cai or dual Cai?
Obviously dual would mean more air and more air better combustion
But is it really worth it to buy a a dual Cai over just a single, intake systems I know don't provide that big of a gain but would dual cold air intakes provide a significant difference?
Thanks
And if there is a DIY on the install could I get a link ?
Old Jul 30, 2012 | 06:13 PM
+fireamx's Avatar
Default Re: dual cai vs cai
An automatic NA car can cut nearly a 1/2 a sec. off its 1/4 mile with a NeedsWings single CAI.
That's a significant amount time.
I think the general consensus here is the NA cars don't need a dual intake, but the SRT's can get more out of it.
Old Jul 30, 2012 | 06:18 PM
32krazy!'s Avatar
according to dragtimes the fastest srt-6 on record without nitrous uses a single cai , 181 pulley dr's, and a tune
Old Jul 30, 2012 | 06:37 PM
+fireamx's Avatar
You did notice I didn't say it was "better" than a single CAI. I just said the supercharged cars got more out of it.
I remember commenting on the thread where the XF with a single CAI beat your SLK with its twin CAI.
I just didn't want to hurt NeedsWings sales, (of dual CAI's) that's all.
Old Jul 30, 2012 | 07:07 PM
Jackerman's Avatar
Thanks guys , I'm gonna be gettin an NA the srt (although I love boosted cars) isnt for me
Too expensive and in that price range I would just get an Audi s4
But the Cai will be my first engine mod
Seems like a dual Cai won't be necessary for me..now all I need is a DIY
Old Jul 30, 2012 | 07:23 PM
If you are buying a new CAI from Rob ( Needswings ), then it comes with instructions.
If you are buying a used one, please be aware there are 2 different versions.
The original one has a bung in the 3" tube for the IAT/MAF sensor and a 90 deg bend that connects to a 90 deg rubber/silicon sleeve that then connects to the throttle body.
The later version uses a plastic piece to hold the sensor between the TB and the 3 " tube.
I have the original one - take a look at my gallery.
You can see the new one on the Needswings site.
The only difficult part of the install is removing the plastic piece by the radiator that the old engine cover plastic pipe connected to ......
NOTE: bite the bullet and replace the 68mm TB with a 74mm one at the same time like I did, then get the tune.
( you can also get a C320 engine cover to hide the naked engine, if that bothers you )
Old Jul 30, 2012 | 07:28 PM
Mrmiata's Avatar
https://www.crossfireforum.org/forum...light=cold+air
Extend it through the radiator mount..
another tidbit:
https://www.crossfireforum.org/forum/515843-post17.html
"while theres no arguement the needswings dual cai is a top notch first rate product you have forgotten an inexpensiive alternative that produces almost as much power as the n/w dual cai and can be had for around 500$. thats the sl55/e55 dual cai setup. looks factory and with k&n filters delivers the goods!"
Old Jul 30, 2012 | 07:43 PM
Jackerman's Avatar
Thanks I will take a look at your gallery after this post , I'm assuming tb= throttle body?
What's wrong with the 68 mm ? Like my op how much of a gain is received after upgradeing?
Getting a tune on the other hand will be way later in the life off the car
But thanks i was actually gonna ask what type mb engine cover fits the xf I just assumed the slk one would work
Old Jul 30, 2012 | 07:45 PM
Jackerman's Avatar
another tidbit:
Thanks for the link
But after amx's post I have decided after getting my new baby she will receive a single cai which I assume is cheaper haven't even looked at prices yet
Old Jul 30, 2012 | 07:48 PM
Mrmiata's Avatar
Originally Posted by Jackerman
Thanks for the link
His setup (link) was $160..and maybe 40 more to carry through the radiator support.. But do what suits you best..
Old Jul 30, 2012 | 08:00 PM
RMADERMAN's Avatar
My SRT has a dual CIA and my daughter's SRT has a single CIA. I consistently run .01-.02 faster then her in the 1/4 mile. This is over a couple of years running aroud 50 times. Both have 181 pullies and the exact same tune.
Old Jul 30, 2012 | 08:03 PM
grip grip's Avatar
Single for the win.
I started with the NW single. Removed it and installed the SL55 intake. Removed it and installed the Dual NW intake. Removed it and installed the Single NW. Long road traveled to be where I started.
Regardless of whether you buy Rob's or build your own, I think the single is the way to go for your setup.
Old Jul 30, 2012 | 08:07 PM
Mrmiata's Avatar
Originally Posted by RMADERMAN
My SRT has a dual CIA and my daughter's SRT has a single CIA. I consistently run .01-.02 faster then her in the 1/4 mile. Both have 181 pullies and the exact same tune.
So your trying to say.. the SRT likes the dual.. but he's looking at an NA which falls short of SC air wants and needs..and has been stated Needswings dual is overkill (I'm guessing your referencing Needswings)..
Old Jul 30, 2012 | 08:09 PM
Mrmiata's Avatar
Single for the win.
I would think Robs single which is plenty of air .. would run real close to some of the DIY duals for intake mass?
Oh... and is this the way the forum is really supposed to work? Discuss things and options without going to war? LOL.
Old Jul 30, 2012 | 08:17 PM
Jackerman's Avatar
This will be quite the job after doing some more searching I was thinking of having a short ram intake custom made by...well myself
But read somethings and changed my mind , then I was skimming a thread and saw a set up of the filter itself being infront of the radiator which looks cool but looks like it would be difficult to install
Doing the Cai on my vw was simple of course It's a 4cylinder with alot of space in the bay
Thanks for all the inputs
Btw what's "NW" mean ?
Old Jul 30, 2012 | 08:18 PM
Mrmiata's Avatar
NeedsWings.. or northwest.. depending on the post your reading.. LOL.
Either way you go, make sure you go outside the engine compartment or you have a HAI (Hot Air Intake) after 3 or 4 minutes of engine startup. I see so many intakes inside the engine compartment and it just isn't a CAI. Dual looks better but for the N/A the single is plenty of air whether you have a tune, 74mm TB, or not. Happy modding everyone and remember the reason the "C" is in front of the "AI" in CAI.
Old Jul 30, 2012 | 08:26 PM
velociabstract's Avatar
Lot's of reply's in a short time. I've had the single and dual and currently have the dual. If you want the best and have the money, for day to day use I'd say the dual. The dual gives a bit more power under the curve while the single and dual are equal in peak power. For racing when your always at high rpm the single is KISS. (keep it simple stupid) I can make a case for either one. It's not an easy call until you know exactly how your going to use your car, what you want comes into play too. Look at your budget and make your choice. Both get the job done much better than the stock system.
Les
Old Jul 30, 2012 | 08:47 PM
32krazy!'s Avatar
That comment wasnt directed at you. it was in response to the op asking which had better gains and dragtimes shows the single wins.
as for the races to set the record straight my car shut down during the race at max rpm due to a bad tcu mod. in a second race i short shifted and evened the score. apples to apples
Old Jul 30, 2012 | 10:00 PM
maxcichon's Avatar
I put this together for some other folks here:
This is for mine, see my signature. Your choice.
Dual CAI Parts List
• 2) Spectre #9833 3" I/O Air Box (Summit # SPE-9833) Summit Racing
• 2) Max-Redline 3" 90 Degree Elbows, Aluminum (M-R # PIP300-90) Max-Redline.com
• 1) Intakehoses.com 3" X 3 1/2" Reducer Elbow (Intake Hoses # 90L35R30)
• 2) Intakehoses.com 3" X 3" coupler (Intake Hoses # C40B-300X3)
• 1) Intakehoses.com Hose Clamp for 3 1/2" ID Hose (Intake Hoses # 64060)
• 7) Intakehoses.com Hose Clamp for 3" ID Hose (Intake Hoses # 64048)
• 1) Intakehoses.com 3" X 3” Tee (Intake Hose # 90T333) Intake Hoses, IntakeTubing, and Intake Clamps
Vendors:
Summitracing.com
Max-Redline.com
Intakehoses.com
