Noise near alternator/pulley? Goes away after on hour of running
Old Aug 26, 2012 | 09:32 AM
2004Blue's Avatar
Default Noise near alternator/pulley? Goes away after on hour of running
Old Aug 31, 2012 | 09:54 PM
MoparFreak69's Avatar
Default Re: Noise near alternator/pulley? Goes away after on hour of running
Could be belt slippage until it warms up enough to burn the glazing off? Maybe a bearing is running dry on lube and makes noise until the grease is warmed up enough to turn liquid and run into the appropriate areas. Are you sure its coming from the alternator itself? Try removing the belt and running the engine for a short amount of time and see if the noise is still there. If it is then you need to look harder to locate the noise. If the noise goes away try spinning all of the pulleys by hand and see if there is any play or noise out of them. They should all spin smoothly with very slight resistance. If you get one that you can flip by hand and it keeps on trucking for a long time then the bearing is worn and should be replaced. The only exception is the alternator, it should spin freely with almost no resistance. The crank pulley obviously wont spin by hand very easily, but there isnt much to go wrong with them aside from losing the rubber in harmonic balancer, but those dont make noise, they come apart when that happens.
Old Sep 3, 2012 | 07:58 PM
amatxcrossfire's Avatar
I had this same problem and the alternator was the cause of the noise. the alternator went out and replaced it with one from auto zone, a lot cheaper then the oem one, just make sure to change out the pulley if you have a srt6
Old Oct 9, 2012 | 04:43 PM
chevyboyac's Avatar
I am having the same issue ....took off the belt a hour ago and it went away....I will post a vid of the noise IMG 6585 - YouTube
Old Oct 9, 2012 | 04:51 PM
chevyboyac's Avatar
Mine doesn't go away in fact its just gotten louder over the last 3 weeks.....its not making the sound 100% of the time but comes in "waves" every few seconds but it really sounds like the alt or very near it......2004blue does your car sound the same? btw I have 120kish miles
Old Oct 9, 2012 | 09:02 PM
Sounds like the alternator might have a bad bearing, mine sounded like yours when it went out, replaced it and no more noise
IGot2P
Jul 26, 2025 12:40 PM
massanu
18
Nov 23, 2015 08:52 AM
velociabstract
15
Sep 7, 2015 03:43 PM
BrenLW
Aug 5, 2015 04:53 AM
axnguyen
Jul 21, 2015 11:41 AM
