speaking of air-conditioning
Old Aug 26, 2012 | 02:35 PM
Default speaking of air-conditioning
On my first start of the day, my air conditioner comes on for about 3 seconds and then stays off while I drive 1 to 2 blocks,, that it will come on and work properly for the rest of the day, anybody else have this problem is this normal or is this just my car? jim
Old Aug 26, 2012 | 04:07 PM
user 72983's Avatar
Banned
Default Re: speaking of air-conditioning
Mine comes on about 5- 10 seconds after I start the engine. Then stays on.
Best AC I ever had in a car! COLD!
Old Aug 27, 2012 | 09:12 AM
Originally Posted by moshei
You should also hire professional technician to inspect your heating system in the fall and your cooling system in the spring. An HVAC service professional can tune up your air conditioning system before you begin using it in the summer.
I don't have summer and winter it is summer year around here and my ac is cold it just ( start the car (with the ac on) The air conditioner blows like crazy, and in that 10 seconds or so, it's cold pretty,Then it stops blowing for approximately 1 to 2 min. then comes on and works perfect rest of the day. this happened every time every morning the car is cold,( car has a run for hours cold)) jim
Old Aug 27, 2012 | 09:22 AM
waldig's Avatar
Talking Re: speaking of air-conditioning
Jim, that is odd and I dont have that operation here. If I punch it hard the a/c goes away for some time until the vacuum returns, I have never checked that but WOT causes a/c to stop during the thrash.Woody
Old Aug 27, 2012 | 09:39 AM
Yes Waldig mine does the same thing at wot but the strange thing is it will sometimes run while i'm backing out of the driveway as soon as i move forward about 20 ft. it goes off and about 2 blocks later it comes on,,, i have to try it at idle and see if it does it there. I am going to go out and start the car ( yes the ac is on it stays on down here ) let it idle for a while and see it it does the same. jim
Old Sep 12, 2012 | 07:47 AM
Well finally my air conditioner stopped working, after doing some research on here, I found out that it could be the resistor, which sits right on top of the fan , underneath the globe box you remove one panel, then you remove the second panel, and you were there. The resistor listed the Chrysler dealer at over $400,and that the Mercedes dealership just under 400.. I found one online for $60, took about 10 min. to put it in, two screws and it's out, use the old red wire because the new was not long enough.
Mine is been running about a week now with absolutely no problems. Jim
Old Sep 12, 2012 | 09:51 AM
Thumper SRT6's Avatar
Hey Jim, where did you order the part from? My AC recently started doing this and I would like to fix it.
Old Sep 12, 2012 | 03:21 PM
http://www.autopartswarehouse.com/details/QQMercedes
This is what I put in the search Blower Motor Resistor 2004 mercedes slk320
2001-2004 Mercedes Benz SLK320 Metrix Blower Motor Resistor
Part: W0133-1716561 Mfr: W0133-1716561
$268.00 $68.95
Quantity Sold: Sold individually
Anticipated Ship Out Time: Same day - 2 business days
Learn more >
Old Sep 16, 2012 | 05:55 PM
Larry Hitze's Avatar
I'll have to get one too, thasnks for the research.
2005 Ragtop
Oct 3, 2015 03:01 PM
Abaton6
Sep 24, 2015 10:14 PM
Vegaslegal
Sep 10, 2015 11:24 AM
Pacemaker
28
Aug 16, 2015 07:33 PM
cjfine
Jul 20, 2015 11:58 PM
