P0100 and Erratic Idle
Old Aug 21, 2012 | 08:03 PM
reiji's Avatar
Default P0100 and Erratic Idle
I picked up a 74mm throttle body today at a local junkyard (came off a E55 AMG ), gently cleaned the throttle plate with some isopropyl alcohol, and got it swapped out. I followed the PDF guide by Rekcah. I performed the throttle reset and started it up.
It started by idling a little high (~1000 rpm). After a few seconds it shot up to 2k and started "surging" between 1.5k and 2k.
I checked every connection and hose in the immediate area and can't find anything loose.
I tried to drive it down the driveway but, it was completely undrivable with the revs bouncing all over the place.
It threw a CEL after a while and gave me a code P0100: MAF or VAF Circuit Malfunction.
The guys at Advance Auto Parts recommended I test that MAF sensor by disconnecting it, then starting the car to see if it runs any different. I did that, and it just stalled out immediately after starting. Should I assume that the MAF is good?
My other mods are TVT intake, magnaflow exhaust, and a Eurocharged tune if that helps.
Any suggestions?
Old Aug 21, 2012 | 10:26 PM
reiji's Avatar
Default Re: P0100 and Erratic Idle
I got some MAF cleaner at the parts store tonight and sprayed down the MAF sensor.
Put everything back together and tried again. The car ran idled like normal, but once I tried to accelerate it went back to the bouncing revs again.
I ordered a new MAF sensor that should be in tomorrow, so I'll find out for sure then if that's the problem.
Old Aug 22, 2012 | 02:05 AM
Hii, did you put the 68mm MAF sensor back in the 74mm housing?
Old Aug 22, 2012 | 07:40 AM
1. did you do a throttle pedal reset ?
2. are you absolutely certain you have no vacuum leak ? ( maybe the new O ring slipped during install, or you overlooked connecting a hose ? )
Old Aug 22, 2012 | 07:49 AM
maxcichon's Avatar
Yep, this sound verrrrrrry familiar!
Old Aug 22, 2012 | 07:52 AM
And then, you could do like Max did : take it to a dealer twice, get no results, then wait a day and the condition will go away. ( I think his roadster cured itself out of fear of another dealer trip )
Anytime mine has an issue, I just head towards the dealer and 9 times out of 10 it will cure itself.
Crossies have a real aversion to Chrysler dealers, sort of like the red headed step child being forced to go home.
Old Aug 22, 2012 | 10:47 AM
reiji's Avatar
I'm actually running the original 68mm MAF AND housing for now. I have to find the bigger housing somewhere.
I've taken the TB off and on several times now and checked the o-ring each time, so I know it's in that groove.
I actually went back to the original 68mm Throttlebody and it did the same thing, but was bouncing between lower RPMs, maybe around 1200 - 1500.
When I press the gas, the RPMs shoot way up to like 4000 and hold there until I shut off the car.
As far as hoses go:
- Y-hose with the 2 connectors on top of the TB
- Hose connected to driver's side of the elbow
That's all of them, right?
Old Aug 22, 2012 | 10:52 AM
yes, that's all the vacuum hoses that might be an issue with this.
so, the throttle reset didn't help ?
you might try disconnecting the negative battery lead for 10 minutes for a complete computer reset .
Old Aug 22, 2012 | 12:53 PM
reiji's Avatar
I've done multiple throttle resets. I tried disconnecting the negative terminal for a good 15-20 minutes.
It's seemed to idle better after that, but as soon as I *tap* the gas, the rpms jump to around 4000 and hold.
Thanks everyone for all the suggestions.
Old Aug 22, 2012 | 03:15 PM
[QUOTE=alaxfire;692834then wait a day and the condition will go away.[/QUOTE]
Mine took more than a day, but this is starting to be more common, I am exchanging PMs with someone who is having the same issue but with installing his intake.
In my case, Max's case, and several others, it worked itself out, but I was still able to drive mine, as it is a manual...
reiji's Avatar
I think I might be going insane...
I stopped at home during my lunch break and started up the car (out of despiration), and it ran fine. I drove it around the block and had no problems at all. I noticed the throttle was a bit more responsive, which is nice.
I drove it back to work (only about a 5 minute drive) and as I pulled into the parking lot, I noticed it idling a little high. I was still able to drive through the parking lot just fine but the RPMs were bouncing around 1000-1200.
I did a throttle reset before I got out, so I'll see what happens when I try to drive home tonight
Old Aug 22, 2012 | 07:33 PM
reiji's Avatar
The problem came back when I tried to drive home tonight. I picked up the replacement MAF sensor that I ordered. I left the battery disconnected while I swapped it out to reset the computer.
No difference with the new MAF sensor.
After narrowing everything down, I'm thinking it almost has to be a vacuum leak, but I don't have any good way to test it. Any suggestions?
Old Aug 22, 2012 | 09:01 PM
reiji's Avatar
So, I got some starter fluid and started spraying the area around the MAF, throttle body, and intake while it was running and got absolutely nothing. I also checked around those valve-cover type thingies on either side.
I'm grasping at straws here...
Would my tune have anything to do with it? Has anyone else had a tune done BEFORE installing the 74mm throttle body?
Old Aug 23, 2012 | 08:00 AM
maxcichon's Avatar
I had to let mine SIT for a week and it magically went away.
Old Aug 23, 2012 | 09:06 AM
I had to drive the ever living **** out of mine on the Dragon, and the problem went away LOL
Old Aug 23, 2012 | 09:12 AM
reiji's Avatar
I got so frustrated at it that I dropped it off at the local import shop to have them look it over. If they can't find anything, I guess I'll just park it for a few more days and let it brew.
Old Aug 24, 2012 | 11:51 AM
a7x6kse6's Avatar
I had to take the screens out of the MAF, baffles out of the elbow and change the spark plugs to fix mine. I would also have eurocharged do a retune. It seemed to help mine as well.
Old Aug 24, 2012 | 03:02 PM
reiji's Avatar
I'll check with Eurocharged once I get the car back. The shop ordered a new OEM MAF sensor. They said that if it doesn't work, they won't charge me for it. I already removed the screens and put in some NGK Iridium plugs a few months ago, but the baffles are still there.
Unfortunately, I have to leave town tomorrow and won't be back until Wednesday. Maybe when I get back, it'll magically have fixed itself like Max's.
Old Aug 24, 2012 | 10:09 PM
reiji's Avatar
I got the car back from the shop. They noticed it running considerably better after they installed the new MAF sensor and did a full reset (touch both battery terminals together for 10 minutes).
When I picked it up, it was still idling around 1000 and didn't drop revs as fast, but it's not spiking 4000 rpm at random anymore. I did a throttle reset and took out to some side roads and beat on it a bit. It still had all the power and seemed to run smoother.
I'm going to have Eurocharged retune it for me and hopefully that will balance everything out.
Old Aug 25, 2012 | 12:33 AM
It was not the battery terminals you touched together or you would want a new battery and maybe hospital treatment, it was the battery cables ends that attach to the battery.
We would not want someone to try that.
When I did my old car I had no trouble, you could have a duff TB connector, bent pin or something.
