Squeal coming from fan at low speeds.
Old Oct 19, 2012 | 05:45 PM
smokey847's Avatar
Default Squeal coming from fan at low speeds.
Just replaced my blower motor because my old one had gone out. I am glad to have found and fixed the problem, but now at low fan speeds, I have a very noticeable squeal coming from the motor. Trying to get this resolved before I put everything back together. Any ideas? Thanks.
Old Oct 19, 2012 | 06:23 PM
MrMoPar's Avatar
Default Re: Squeal coming from fan at low speeds.
I just pm'd you information on what to check and most likely way to eliminate it.
Old Oct 19, 2012 | 06:26 PM
Is it a secret? LOL
Old Oct 19, 2012 | 06:38 PM
Is it a secret? LOL
I saw it once. It's "eyes only", "burn after reading"
Information like this is not safe in the hands of the unwashed masses.
Old Oct 19, 2012 | 07:23 PM
bluecoupe's Avatar
This'll work.........
Old Oct 19, 2012 | 07:30 PM
smokey847's Avatar
Tried lubricating both ends of the shaft as MrMoPar advised. Still an annoying whine. Any other suggestions?
Old Oct 19, 2012 | 08:46 PM
The use of oil, now that's some secret. LOL
Is it a new motor? I guess not. Does it have ball bearings or bronze bearings?
Old Oct 19, 2012 | 09:23 PM
Indelibility's Avatar
Lube? Shaft? Now I know why it was sent as a pm, lol.
When you put everything back together, did you accidentally over tighten anything?
Old Oct 19, 2012 | 10:43 PM
smokey847's Avatar
Nope. All that was put back in was the four screws holding in the motor and two holding in the resistor.
Old Oct 19, 2012 | 10:48 PM
smokey847's Avatar
Took a video of the noise to give you a better idea:
http://www.youtube.com/watch?v=o3-rk...ature=youtu.be
Old Oct 20, 2012 | 08:28 AM
Chrysler Crossfire HVAC Squeal - YouTube
Not sure on this one. It almost sounds like it's underpowered, like its struggling to put out power.
Maybe check your intake plenum and make sure it's not blocked with leaves or debris.
Old Oct 20, 2012 | 09:19 AM
I think I'd be tempted to take it out and put it on the bench with my riding mower battery so I could tell a little better what was happening .....
Old Oct 20, 2012 | 09:22 AM
MrMoPar's Avatar
Is it a secret? LOL
No, it is not a secret. He is having an apparent issue with a used part. I simply prefer to deal with any type of issue such as this via direct communication, not via forum posts.
Same line of thought, oil ends of shaft, check installation, make sure no debris.
Instead of direct communication with me, there are two lines of communication started. One I have direct involvement in, and one I do not.
Old Oct 20, 2012 | 01:02 PM
smokey847's Avatar
SOLVED
Replaced old resistor with the new one I had ordered to originally diagnose the problem and this stopped the noise. So, as it turns out, it appears that my original resistor went bad, thus frying the original blower motor. I replaced the blower motor with the new one MrMoPar sold me, running it through the original resistor. The fan now worked, but there was an awful squeal coming from the vents. I then replaced the resistor as well and the problem ceased.
Thanks for the suggestions and help from all.
Old Oct 20, 2012 | 02:18 PM
MrMoPar's Avatar
SOLVED
Great, glad is worked out.
So we have found a data point, if fan starts acting up, most likely resistor failing. Replace it before it fries the motor.
Kodebuster
Nov 5, 2020 04:06 PM
Hoppy
Dec 7, 2018 07:36 AM
gp1200x
Dec 6, 2015 12:59 PM
waldig
Sep 2, 2015 11:02 AM
hhr hellshotrod
Aug 17, 2015 11:27 PM
