Camshaft Sensor
Old Nov 1, 2012 | 09:18 AM
hpmotors's Avatar
Unhappy Camshaft Sensor
My 05 Coupe w/six speed has a problem. Twice it has cut off - immediate shut down as if the key had been switched off. Once I was idling in traffic, the second time I was turning into my drive. Both times the car had cranked up normally and was driven about 5 miles before the problem occurred. When motor shut off, it would crank normally but not start. No misfires or anything, just the engine spinning over. After about 45 minutes, car would start normally.
Engine code came up with camshaft sensor issue. The camshaft sensor has no moving parts, so I am puzzled as to how it apparently fails and then works again. How common a problem is this? Has anyone else used aftermarket sensors or have you just used Chrysler bits for repairs.
First mechanical issue I've had with this thing in six years of ownership - but haven't driven it that much as it has about 40K on it.
Old Nov 1, 2012 | 09:24 AM
Default Re: Camshaft Sensor
Crankshaft sensor works in the same way a Camshaft sensor does. Heats up, fails, cools down, will work again for a while.
Buy a name brand sensor, cheaper ones may not work properly, been there done that.
James
rampntlion
21
Feb 11, 2019 08:18 AM
mobilefitt
Sep 24, 2015 01:04 PM
caseydeankopp
Sep 13, 2015 07:25 PM
bobbie
Sep 12, 2015 12:49 PM
2004_
Sep 4, 2015 01:39 PM
