Intercooler replacement tips, anyone?
Old Dec 2, 2012 | 05:44 PM
velociabstract's Avatar
Default Intercooler replacement tips, anyone?
My new intercooler arrived and I took a peek at the manual to get an idea what I'm in for but it's pretty dry. Remove this, reinstall that. I know a bunch of you have done this job ..... some several times. Any info you can give me that's not obvious? Where does the sealant go, exactly. Any tips will be appreciated. Oh, photos of Rob's MB thermal coated I/C.
Les
Old Dec 2, 2012 | 07:42 PM
32krazy!'s Avatar
Default Re: Intercooler replacement tips, anyone?
sealant goes on the intake side. let it get tacky. watch how you route the purge valve lines they go in between the i/c and the s/c be very careful NOT to drop the mounting bolts into the engine valley!! use a magnet. the 2 mount bolts in the front will be diffucult with the i/c lines installed. the fittings on the i/c get in the way when aligning the bolts in the hole. dont strip or crossthread them . you may want to remove the fittings and reinstall them later
Old Dec 2, 2012 | 08:19 PM
tunaglove's Avatar
This motor is thought out so well its a breeze to work on. Replace the metal gasket under the lift ring in the back passenger side. Use the Merecedes sealant on the ic, you will see how they did it when you pull it apart.
Old Dec 2, 2012 | 08:24 PM
tunaglove's Avatar
The hardest part for me was pulling the fuel rail up and off. Hint, removing the black cover from the brake booster push lok will give you just enough room.
Old Dec 2, 2012 | 11:29 PM
BrianBrave's Avatar
<--- Huge Horsepower
Notice the RTV on the edges of the gasket...
Old Dec 3, 2012 | 07:32 AM
Thanks for the info. It seems silly to ask but .... I'm assuming the supercharger and intercooler come out as one unit and I can disassemble and assemble it on the bench. How heavy is the assembly? approx. (old back, weak mind at work here) I've been advised to expect 6 hours without complications so I'm giving it 2 weeks. J/K. Anyone run a meth line under the works? It seems like a good time to do it, don't you think?
Les
Old Dec 3, 2012 | 09:01 AM
tunaglove's Avatar
It's not too heavy. Put some moving blankets on your fender so you can brace yourself against it.
Old Dec 3, 2012 | 09:09 AM
grip grip's Avatar
I wouldn't install any type of jet (nitrous or meth) into the intercooler due to lack of accessibility. The last thing you want to do is pull the SC to change jets.
Old Dec 15, 2012 | 09:33 AM
I ended up putting the water/meth nozzle in the Y pipe. A test later today (tonight actually) is in the works to see if the boost prevents the sensor from seeing a drop in temperature. (I haven't sprayed yet after the change) The nozzle is flush on the inside of the Y and angled to spray in front of the IAT sensor. My fingers are crossed that it reads lower temperatures.
My old intercooler doesn't look too bad, perhaps all the spraying through the blower cleaned it up. So far my IAT's in traffic are the same as before, around 30º over ambient. On the highway they are more or less 20º over. More testing is needed before saying for sure.
It's logical, at least to me, to replace the I/C pump. 20º over ambient seems a bit high. So Rudy, pull the Pierburg or I'm ordering something else!
Les
Boresite
Aug 9, 2015 10:33 AM
Romio
Jul 24, 2015 07:03 AM
rmcdaniel12
Jul 21, 2015 11:35 PM
RED DOG
Jul 21, 2015 07:58 AM
Beeker
Jul 20, 2015 03:46 PM
