New to site ... Question
Old Feb 24, 2013 | 10:24 PM
backnblack's Avatar
Default New to site ... Question
I have a 2005 Crossfire, 65000 miles on odometer, 6 speed manual
I have just recently noticed a slight whining noise coming from the front of the engine. I am no mechanic, but it sounds like maybe a pulley or belt. It is faint, but it does increase with engine RPMS. It is most noticeable when decelerating and shifting back into second or first when the RPMS are dropping back to idle. No warning lights and no problems I have noticed - other than the faint sound. Any ideas ?
Old Feb 25, 2013 | 06:23 AM
Default Re: New to site ... Question
use a 3' or so section of 3/4" hose from you ear to the different areas suspected.
BE CAREFUL !!
Old Feb 25, 2013 | 05:18 PM
backnblack's Avatar
Thanks for info. It looks like an easy fix and I did not think the sound seemed to be too serious. Fortunately this is not beyond what I can repair / replace myself.
Old Feb 25, 2013 | 06:19 PM
You will find that the fan/shroud assemble is really easy to remove, and you will gain excellent access to all the spinney stuff.
Old Feb 26, 2013 | 10:29 AM
First try a small water bottle with some water in it and with the engine running carefully squirt a stream of plain water onto the inside ribbed surface of the serpentine belt. If the noise goes away, replace the glazed belt and leave all the rest of the stuff on (unless you are like me and love to tear into things to see how they come apart and go back together).
Old Feb 26, 2013 | 10:55 AM
witchal's Avatar
I'm betting on a pending idler pulley grenade.
rampntlion
21
Feb 11, 2019 08:18 AM
Canyonero
Oct 6, 2015 09:23 PM
FISHBONE
Sep 17, 2015 06:15 PM
xjken
Sep 6, 2015 11:37 AM
