Has my crossfire got a iod wcm fuse ??
Old Feb 27, 2013 | 01:42 PM
wrapper484's Avatar
Exclamation Has my crossfire got a iod wcm fuse ??
Has my 2004 crossfire got a iod wcm fuse as the imobliser wont allow it to start
Old Feb 27, 2013 | 01:47 PM
Default Re: Has my crossfire got a iod wcm fuse ??
IDNKWYH so explain STWCAUY.
Old Feb 27, 2013 | 02:17 PM
Couldn't have said it better myself
Old Feb 27, 2013 | 02:57 PM
waldig's Avatar
Talking Re: Has my crossfire got a iod wcm fuse ??
LMAO n ROTFL
WW
Old Feb 27, 2013 | 04:06 PM
Airscape's Avatar
That's definitely part of the flux capacitor. :P
On a serious note though since you are new there are several no start/starting issues that have been solved. CPS,RCM etc. searching may help otherwise some more detail is needed to help you.
Old Feb 27, 2013 | 07:21 PM
It's probably a defective transvector columnization regulator valve .....
Them TCRV's can drive you crazy ...
Old Feb 27, 2013 | 10:45 PM
mferreira3417's Avatar
iod fuse = ignition off draw
it is a fuse that you can pull if your car is going to set for a long time and will not run the battery dead. Most new cars come with it out from the factory and tech installs it when doing a new car prep.
it will not affect whether the car starts or not.
does the car start and die in a couple seconds?
you car try leaving the key in the on position for 30 minutes and it might reset itself.
of course with a battery charger hooked to battery.
i have seen it work a couple times myself.
wcm = the style of fuse if memory serves me.i do not believe that the crossfire comes with iod fuse
Old Feb 28, 2013 | 08:34 AM
Please describe what happens when you turn the key.
1. Do all the dash lights come on ? ( battery / grounds )
2. Does it do nothing when you go to the 'start' position ? ( probable RCM problem )
3. Does it spin the motor but not start ? ( Crankshaft / Camshaft position sensor )
Old Mar 5, 2013 | 05:31 PM
wrapper484's Avatar
My car starts and runs fine for a moment most dash lights go out before she stops 2or 3 times then key is dead untill i remove battery terminal have fitted new crankshaft senser and new relay control unit what should i do next ? i am baffeled !
Old Mar 5, 2013 | 05:43 PM
wrapper484's Avatar
rear spoiler has come up and wont go down again
Old Mar 5, 2013 | 05:45 PM
Mrmiata's Avatar
Take it... to the dealer..one more tiiame.. (as sung to the tune by the eagles).
Hate to be the grim reaper here.. but sounds like the skreem module is not going to play nice any more.
Old Mar 5, 2013 | 07:05 PM
We have had this problem before, was the BCM at fault?
I will check.
Sorry I can't do that in this thread, Body Control Module. LOL
Gunner (?) in the UK had similar problems but went AWOL before telling us what happened I think.
Old Mar 6, 2013 | 10:16 AM
sk8erjosh09's Avatar
Just for future reference it's 1 hour. I just saw it yesterday for the first time in the manual lol
Old Mar 6, 2013 | 10:20 AM
Mrmiata's Avatar
Mental note taken.. I know I'd read 30 minutes on the forum in the past.. don't guess you noted secton and page by chance?
Old Mar 6, 2013 | 11:07 AM
8E - 55 in the service manual second paragraph starting with "Note:"
ingsoc39
Nov 25, 2019 05:44 PM
carmax
Jun 18, 2015 01:30 PM
RyanB
Jun 11, 2015 10:25 AM
MJPowers
Jun 8, 2015 02:34 AM
gobraves423
Jun 6, 2015 07:03 PM
