Ignition Lock Assembly Help...
Old Mar 3, 2013 | 12:05 PM
blackbee's Avatar
Default Ignition Lock Assembly Help...
Hey All,
I'm new here and just purchased a crossfire. It has the sticky ignition issue...
I can do the work myself, but I don't know where I should order the Lock Assembly from.
Help please...
Old Mar 3, 2013 | 12:10 PM
Mrmiata's Avatar
Default Re: Ignition Lock Assembly Help...
You don't have to replace the lock assembly.. Thats kinda the purpose of the fix..
Old Mar 3, 2013 | 12:14 PM
blackbee's Avatar
From what I see in the PDF it's saying to get the New Assembly?
Old Mar 3, 2013 | 12:18 PM
Mrmiata's Avatar
https://www.crossfireforum.org/forum...key-fix_v2.pdf
Version 1 or 2 ? LOL..
Last page should have "re-using old assembly"
https://www.crossfireforum.org/forum...0-post197.html
Old Mar 3, 2013 | 12:53 PM
blackbee's Avatar
So are you saying to drill that PIN out I will have the issue resolved?
Old Mar 3, 2013 | 01:04 PM
Mrmiata's Avatar
I'm saying no need for new assembly.. This is on my list of things to do.. but it looks like as long as you can rotate the key to "position 1" you wont have to drill .. just modify and remove the pin and spring..
I'm not locked up..just somewhat catchy at times.. gambling on borrowed time.. LOL
Old Mar 3, 2013 | 01:48 PM
user 72983's Avatar
Banned
Me. Too
Old Mar 3, 2013 | 05:11 PM
cmz's Avatar
cmz
mine would sort of hang up once in a while too. did the mod as a preventive. do it before the key wont rotate and you wont have to drill the pin. cmz
Old Mar 3, 2013 | 06:56 PM
+1 to that. Mine was getting 'catchy', so I broke down last week and did the fix.
3 notes :
1. Where it says to press the 2 ears to release the transmission locking cable, you don't try to slide it back like it was an electrical connector, you pull down ( away from the lock assembly ) to release.
2. I found it much easier to remove the ignition electrical harness if you wait until you can rotate the assembly in the clamp.
3. Use an ice pick or something to line up all the panel holes and brackets during reassembly.
fastfred
Nov 5, 2018 09:47 AM
Mackel
Oct 16, 2015 09:03 AM
4drturbo
Oct 2, 2015 12:58 PM
Selbyl
Sep 26, 2015 04:15 AM
fastfred
Sep 24, 2015 03:05 PM
