Ignition switch
Old Mar 12, 2013 | 03:23 PM
daniel miranda's Avatar
Default Ignition switch
I need help ! The key of my crossfire won't turn and of course the car won't start. I had to towed the car to a mechanic ! They told me it was going to be the ignition switch , but they just called me and said they need to change the whole housing switch something ! Because they can't just change the ignition switch ! Anybody have had the same problem ! It's going to cost 1000$ does anybody could help me to see if that's about right , or maybe other way to fix it ! Would I have to take it to the dealership to code the key ? Hope anybody could help me ! Thanks
Old Mar 12, 2013 | 03:45 PM
Default Re: Ignition switch
search for "Sticky Ignition Key Fix"
Old Mar 12, 2013 | 03:49 PM
Mrmiata's Avatar
Print it out .. take it to them.. and tell them you'll gladly pay a reasonable labor rate ..
Old Mar 12, 2013 | 03:59 PM
So with that they can get the ignition switch replace without changing the housing switch ?
Old Mar 12, 2013 | 04:00 PM
I'm right here in the parking lot of mechanic place
Old Mar 12, 2013 | 04:05 PM
With that, there should be no charge beyond simple labor ...
It is a printable .pdf file with pretty pictures.
Old Mar 12, 2013 | 04:07 PM
the URL is :
https://www.crossfireforum.org/forum...key-fix_v2.pdf
tcar32909
Aug 1, 2024 02:41 PM
Osusannah
Feb 12, 2024 01:49 PM
fastfred
Nov 5, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
fastfred
Sep 24, 2015 03:05 PM
