NA Engine Stuttering
Old Mar 13, 2013 | 05:29 PM
2008XF's Avatar
Default NA Engine Stuttering
Hi, for the past 2 days my engine has started stuttering when i come to a stop. i
it doesn't happen all the time, but randomly, about 1 in every 15 stops or so.
when i give it gas its back to normal.
i recently got my spark plugs and wires changed last week, and did oil change on the weekend.
could any of those be the issue?
Old Mar 13, 2013 | 06:23 PM
Default Re: NA Engine Stuttering
Spark plugs? Yes they could be the trouble if they were not installed correctly, did the problem occur at that time more or less considering it happens every 15 times or so?
Old Mar 13, 2013 | 06:55 PM
2008XF's Avatar
I got the spark plugs installed last wednesday, i drove windsor to caledon thursday and back to windsor on monday and no problems. the problem just started monday.
Old Mar 13, 2013 | 07:14 PM
Selbyl's Avatar
I just had this issue last week and fixed it.
https://www.crossfireforum.org/forum...on-sensor.html
I took out the throttle body and MAF and cleaned them both, cleared any codes, did a throttle reset and then drove around about 50 miles to make sure everything is calibrated and it runs just like it did before.
Old Mar 13, 2013 | 07:21 PM
2008XF's Avatar
do i have to buy a new sensor?
is this one ok?
Mercedes Camshaft Cam Position Sensor W140 W129 W210 | eBay
Old Mar 13, 2013 | 07:25 PM
I guess it's not the plugs then, see selbyls reply.
Your the guy just down the road from me that I saw last year.
Good luck.
Old Mar 13, 2013 | 07:27 PM
Selbyl's Avatar
I would clean your MAF first, a can of MAF cleaner and throttle body cleaner is $10.
I originally thought my crankshaft or camshaft sensor was going back but then I finally got a MAF code so I cleaned everything and it works great now.
It helps to have an OBDII adapter and Torque if you have an android phone, iPhone has their own app as well. $30 for the best code reader I've ever used.
https://www.crossfireforum.org/forum...tml#post728471
Old Mar 13, 2013 | 07:40 PM
2008XF's Avatar
I dont have any engine light on right now, but ill clean the maf and give it a try.
yes onehundred80 that was me,
Old Mar 13, 2013 | 07:44 PM
Selbyl's Avatar
I didn't have an engine light on either but my app was still showing pending and fault codes for the MAF, I had code P0101.
I had a bit of stuttering after I cleaned the MAF so make sure you drive enough and mixed driving helps too, spirited and stop n' go will help everything calibrate again.
And if this doesn't work you're only out $10. But if it does work, you save $150.
Old Mar 13, 2013 | 07:51 PM
2008XF's Avatar
Thanks, i will try it tommorow
Old Mar 13, 2013 | 11:31 PM
arejohn's Avatar
is this one ok?
I think its the crankshaft position sensor that usually faiils and Bosch is the recommended vendor.
I hope so because that's the spare I carry.
Old Mar 13, 2013 | 11:40 PM
2008XF's Avatar
I am thinking it is also, so i ordered this one from needswings
Crank Position Sensor
janaiy
53
Nov 2, 2015 09:23 PM
crossfireusa
Oct 28, 2015 12:03 AM
RacerXofFL
Sep 15, 2015 05:00 PM
BEATv1
Sep 10, 2015 12:58 PM
MickeyNasty
Sep 6, 2015 08:29 PM
