low coolant light comes on and off.
Old Mar 28, 2013 | 06:33 AM
figgy7935's Avatar
Default low coolant light comes on and off.
Yesterday my low coolant light came on and off a couple of times. The engine temp gauge is running below the mid point as it normally does. I checked the overflow tank and noticed it was half full. My question is there is no indicator line on the tank that tells me how high the level should be. Does that mean that I should top off the tank? Any help will be greatly appreciated
Old Mar 28, 2013 | 09:43 AM
witchal's Avatar
Default Re: low coolant light comes on and off.
I had the same issue. It started sporadically and after a year just stayed on. You may need to replace the Coolant Level Sensor.
Mercedes-Benz SLK32 AMG Parts & Accessories Online | FCP Euro
Old Mar 28, 2013 | 09:56 AM
There is a rib inside that stands vertically at the rear of the tank, the correct level is when the fluid reaches the top of the rib. Basically it's to the top of the clearer part of the tank, just where the black part starts.
Old Mar 28, 2013 | 10:19 AM
figgy7935's Avatar
Thank you very much for the info. John
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
gp1200x
Dec 6, 2015 12:59 PM
Ralph289
Jul 26, 2015 12:52 PM
Tp'sfury
Jul 17, 2015 01:15 PM
