Full OEM style push start ignition and start!
Old May 5, 2013 | 11:11 PM
Jamerian's Avatar
Default Full OEM style push start ignition and start!
i finally finished it... took along time. Fully custom.
Old May 5, 2013 | 11:26 PM
Default Re: Full OEM style push start ignition and start!
VID00000020 - YouTube
That is neat, are you going to do a write up on how it's done?
Old May 5, 2013 | 11:40 PM
orlando2128's Avatar
Where does the key go?
Old May 5, 2013 | 11:47 PM
Jamerian's Avatar
Ya ill do a write up. Will take a while though...
Dont have to use keys at all. I just push the button and go.
The car actually unlocks and disarms the security and even puts up the spoiler when i walk up to it... That video will be added tomorrow in the exterior thred. So i dont really have to do much to start and drive anymore.. Im a lazy guy haha
Old May 13, 2013 | 08:54 AM
Kmargaitis's Avatar
I would really like to know more info on how you did this.
Thanks
Old May 13, 2013 | 07:30 PM
Selbyl's Avatar
I would love to see how you did the auto unlock and spoiler up. Some sort of RFID set up?
Old May 13, 2013 | 08:15 PM
Whoapony's Avatar
Subscribed!
Old May 13, 2013 | 08:36 PM
Very cool!
Old May 19, 2013 | 10:55 PM
Jamerian's Avatar
its a cool device called Dei 2102t from ebay. It sends a ground pulse when you approach the module while holding a special FOB, and a different ground pulse for walking away from it. i used 6 relays 4 diodes, a timer relay(dei 611t), an on/off switch (for when you want it to stay put) and a couple headaches....
ill make a write up for this as well. the spoiler syster was designed as a simple motor with 2 limit switches. the BCM moves the motor up and down and knows where it is via the limits. the limit switches send a ground to the bcm. so my set up is 2 relays that act as up and down controllers and 2 more relays to stop the motor when it reaches its limits and the last 2 relays convert the ground outpus of the dei2102t to positive. the timer relay dei611t controls power to the down circuit and was added late in the project because i noticed my battery dying :S. anyway.. heres the video.
Dei 2102t on crossfire. wired to spoiler too. - YouTube
Old May 20, 2013 | 01:37 AM
Selbyl's Avatar
Really awesome setup man. The only thing I would add would be a set up where the spoiler would automatically go down when the car is in reverse and then back up when the car is put back in gear. I'm thinking it would work if you tap into a negative signal from one of the reverse lights.
Can't wait to see your schematic.
Old May 20, 2013 | 04:26 AM
Jamerian's Avatar
thank you thank you. thats actually a good idea. making it go down would work.. to to find a signal when you put it in gear is the hard part.
Old May 20, 2013 | 09:23 AM
JHM2K's Avatar
Subscribed.
Old May 20, 2013 | 04:01 PM
Looks very interesting, I am impressed
If someone broke your window, pushed down the brake and clutch, would they have stolen your car or did you wire in a cutoff or safety?
Old May 20, 2013 | 05:52 PM
Jamerian's Avatar
good question! Aside from the annoying wisel of the factory alarm that will go off , the dei 2102t has a starter kill feature. it sends out a ground when you walk away from it.. so u can wire that to a relay which can cut any and how many circuits u like.
Old May 20, 2013 | 07:52 PM
Selbyl's Avatar
Yeah that might be a little hard. Another easy one would be to have a relay turn on your underglow. That's something I've wanted to do to my car as well.
Old May 20, 2013 | 09:31 PM
Jamerian's Avatar
wire them to your domelight circuit! since your domelights come on when you unlock the vehicle the underglow turns on and even fades out when the lights fade out. looks really neat.
Old May 20, 2013 | 10:34 PM
Selbyl's Avatar
And then have it wired into a switched circuit so that they're always on with the car... Can we get anymore lazy? I mean automated?
Old Sep 19, 2013 | 12:48 PM
hecti's Avatar
Where is the write up on how to do this!!??!!
Old Nov 10, 2013 | 10:11 AM
DBLewis's Avatar
What about the steering and gearshift lock? Would it always be disabled?
Old Nov 29, 2013 | 10:53 PM
psuperti's Avatar
super cool, well done!
