Wiring gauges?
Old Jun 20, 2013 | 02:09 PM
scomer88's Avatar
Default Wiring gauges?
Hi all,
I am bout to start wiring in two gauges on the a pillar and i have a few questions.
The instructions say i need a positive 12 volt constant (un-switched) source, a positive 12 volt ignition (switched) source, any good (unpainted) ground connection. Where would be the best spots for each of these, and where is the best spot to run wires through the firewall on the drivers side of the car? Thanks alot for any help.
Old Jun 20, 2013 | 02:23 PM
Default Re: Wiring gauges?
Originally Posted by scomer88
Hi all,
To run the wires, remove the trim above the pedals (takes, if I remember, two screw's removal and that panel comes out). Under the hood, take the cover off the driver's side fuse box. You can use a STIFF rod or wire, feed it into the corner of that box, and it'll come out under the dash thru a passage that a lot of wires run thru. Plenty of extra room! Tape your wires to the rod and pull them thru with the rod.
I can't remember where I picked up my ground for my oil gauge, it was somewhere under the dash.
You will find switched and unswitched power in the fuse box that you took the lid off. Use one of these to get power out of the box:
These are available at AutoZone and other places (like WalMart).
The bottom fuse pins are for the fuse that was in the spot you are using.
The top pins are for the fuse that will power the red wire that goes to your gauge.
Just make sure you orient it so that power is on the left blade and load is on the right. If you put it in backwards, all of the current for the existing circuit and added circuit go thru the bottom fuse - not a BIG deal, but not really the right way to do it. Confirm withe a voltmeter which pin is hot after you pull the fuse!
(The two pins on the left connect to the blade on the left, the bottom right pin connects to the right blade. The top right pin connects to the red wire - got it?)
yer welcome....
Old Jun 20, 2013 | 02:30 PM
scomer88's Avatar
So i would need to buy two of those? one for the switched and one for the unswitched fuses? And you wouldnt happen to know which fuses are switched/unswitched off hand would you?
Old Jun 20, 2013 | 04:30 PM
You would need two, yes.
The owner's manual will give you an idea of what fuses are good candidates. When I get time, I'll look to see what two I used.
I have an oil pressure gauge installed and I also have modded my car using those dual fuseholders to make my glovebox light and lighter plug hot all the time.
amx1397
Oct 2, 2015 05:20 PM
Sep 28, 2015 07:40 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
xfireon20z
Sep 10, 2015 04:27 PM
RiderJC
Sep 7, 2015 11:19 PM
