Suspicious engine behavior...
Old Jul 2, 2013 | 11:22 PM
lildaddym's Avatar
Default Suspicious engine behavior...
There are times when driving our car I can feel a difference in power...not sure I'm describing this where anyone can understand... especially if I don't give it as much gas...don't know where to start on troubleshooting this one. Almost acts like some plugs are not firing correctly...
Car starts fine; lights off almost instantly.
Old Jul 3, 2013 | 12:16 AM
NeedsWings's Avatar
Default Re: Suspicious engine behavior...
pull the codes and post them up
Old Jul 3, 2013 | 01:04 AM
lildaddym's Avatar
No odes... First thing I checked for...see if any come up when we go to the office...
Old Jul 3, 2013 | 10:15 PM
lildaddym's Avatar
Didn't get a chance to get any codes today, but I did notice that annoying voltage drop...Torque tells me that the voltage from the alternator dropped from 12.9 to 12.5V...
Old Jul 7, 2013 | 07:05 PM
lildaddym's Avatar
Finally got a code...P0305...Cylinder #5 misfire...
Old Jul 7, 2013 | 09:21 PM
So your first guess was right!
Old Jul 7, 2013 | 09:27 PM
lildaddym's Avatar
Pretty good, huh! Now to figure where it's coming from...I was going to try the fuel filter first...
Old Jul 7, 2013 | 11:50 PM
Mrmiata's Avatar
Thoughts on swapping around the coil packs to see if misfire follows?
Old Jul 7, 2013 | 11:55 PM
lildaddym's Avatar
Sir, that was part of my plan...I went back out to double-check the code with Torque, and the car seemed to run fine...didn't drive it, but it started up right away. Think I should do that before I spend the money on the fuel filter, even though I can't vouch for it's condition?
Old Jul 8, 2013 | 06:48 AM
Mrmiata's Avatar
Well the swap is free to do. But at 120k I wouldn't just forget about the filter. Like me (110k) your about due..
Note: make SURE you get a quality one like Needswings sells! Others have purchased off brands and traced back to a problem with the pressure regulators in them...
Old Jul 8, 2013 | 07:18 AM
Here is a good write-up on the P0305 code :
OBD II Code P0305
Old Jul 8, 2013 | 10:51 AM
lildaddym's Avatar
OBD II Code P0305
Thanks for the info, sir!
Old Jul 13, 2013 | 07:19 PM
lildaddym's Avatar
There's not any real way to put the fuel filter in backward, is there? I installed mine (without noting how the old one was) with the arrows pointing to the passenger side of the car...
Old Jul 13, 2013 | 07:46 PM
Mrmiata's Avatar
Check against this..
Old Jul 13, 2013 | 07:50 PM
lildaddym's Avatar
I've got that diagram, but I wasn't able to make heads or tails of it...on another note, the filter I got from AZ was a Mann filter...I was surprised!
Old Jul 13, 2013 | 09:42 PM
Mrmiata's Avatar
Decided I've waited long enough.. 113k and trip this fall. I looked at Autozone online and didn't see a Mann filter listed.. so just went this route. Edit: With Torque Pro I've notice long term fuel trims run along 4.5 to 7.2.. curious to see if this changes.
http://www.ebay.com/itm/MANN-FILTER-WK-720-Fuel-Filter-/261050980078?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACrossfire&hash=item3cc7d9d6ee&vxp=mtr
Old Jul 13, 2013 | 10:18 PM
I'm at 94,000 - I better order one, too.
Old Jul 13, 2013 | 10:29 PM
lildaddym's Avatar
Mann Filter WK 720 Fuel Filter | eBay
It's not listed as a Mann filter...comes in their house brand...39.99...
Old Jul 13, 2013 | 10:39 PM
What do yo mean? I see a Mann filter and part number.
Old Jul 13, 2013 | 11:22 PM
lildaddym's Avatar
I guess I was lucky...the box I got, labelled "FF868DL" and with their 'Everlast" (?) brand contained a Mann filter...
