Wheel Spacer Problems!!! Ahhhh
Old Oct 8, 2004 | 07:35 AM
bmerfan's Avatar
Default Wheel Spacer Problems!!! Ahhhh
Guys, the episode goes on!
I received new Eibach 10mm spacers for the car, installed on all front and back and all went to plan.... shock / horror! I got all of vibration like the wheels required balancing, took off the front wheel spacers and all was good!
No idea why, the fit was tight and perfect, the spacers seemed to be in perfect condition, so why???
I've kept the rears on, car does handle and looks superb.. but why can I not get the front to perform without vibration, I have no idea.
HELP!
Old Oct 8, 2004 | 09:40 AM
MAXIMA's Avatar
Default
CAN YOU PROVIDE EIBACH REAR WHEEL SPACER PART #.
ALSO, DID YOU USED FACTORY REAR WHEEL BOLTS?
Old Oct 8, 2004 | 10:00 AM
bmerfan's Avatar
Default
I shall get hold of the part number.. and also used extended wheel bolts too... same for the rear.. rear wheels are fine.
Old Oct 8, 2004 | 12:00 PM
NJspeed69's Avatar
Default
That's so wierd.. if it was the wheels, it would still vibrate when you take the spacers off, so it's not that.. so don't try getting them balanced...
I'd say maybe the spacers are slightly defective.. I mean thats the only thing that I can think of anyway.. if they are even a quarter milimeter off somewhere, it could affect the way the tires roll at, and cause a vibration.
Old Oct 8, 2004 | 12:40 PM
bmerfan's Avatar
Default
just so confused.... and annoyed at this!!
Old Oct 8, 2004 | 03:53 PM
NJspeed69's Avatar
Default
Maybe you didn't torque em right either..
Old Oct 8, 2004 | 03:58 PM
bmerfan's Avatar
Default
they where installed by a team of professional BMW race engineers.. the fit and torque was perfect.
Old Oct 8, 2004 | 04:29 PM
pnsji's Avatar
Default
bmerfan,
make sure you get a hub-centric spacers. Otherwise, you might get vibration at high speed.
Old Oct 8, 2004 | 06:02 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Wheel Spacer Problems!!! Ahhhh
HELP!
the eibach spacers must NOT be hub centric...h&r's are...go with the h&r spacers.
Old Oct 8, 2004 | 07:08 PM
bmerfan's Avatar
Default
they are hun centric... this is why I am so lost on this...
Old Oct 8, 2004 | 08:10 PM
pnsji's Avatar
Default
Does your spacers look like the one posted above? there is a center ring.
Old Oct 8, 2004 | 10:59 PM
Dan Root's Avatar
Banned
Default
It could still be the wheels only the spacer brings out the problem more.
Try the rears on the front.spacers I mean.
Old Oct 9, 2004 | 10:39 AM
andrew's Avatar
Default
are you tightening the lugs on apposing sides...crossing from side to side as you tighten them? then using a torque wrench to 81 lbs.
can you take some pics of the spacers and post them?
Old Oct 10, 2004 | 10:04 AM
saldous's Avatar
Default
Can't the garage who lowered your car fix this for you?
PNA
Nov 12, 2020 04:44 PM
maxcichon
May 14, 2019 07:30 PM
velociabstract
Aug 7, 2015 01:30 PM
MSCrossfire42
Jul 27, 2015 07:59 PM
Buchacho
Jul 9, 2015 04:13 PM
