Where to mount a Satelite Radio Antenna
Old Oct 18, 2004 | 12:29 PM
Heb80's Avatar
Default Where to mount a Satelite Radio Antenna
Where are you guys mounting your satelite radio antennas?
Old Oct 18, 2004 | 01:46 PM
Sandman's Avatar
Default Re: Where to mount a Satelite Radio Antenna
It is best for it to go on out side of vehicle, but if you want you can put some up in the front dash. If for some reason you get any static you would need to place it on roof or back hatch area.
Regards,
Old Oct 18, 2004 | 01:59 PM
mightyjlr's Avatar
CrossfireForum.org Founder
Mine is on the the hatch. I actually prefer the look of the car with the antenna there than with it not. I will take a picture and post it later today.
Old Oct 19, 2004 | 10:56 PM
PhillyXFire's Avatar
I have the really tiny GPS and XM antennas mounted inside the front windshield between the vents. They're not obtrusive at all, and I have not had any reception problems.
Old Oct 21, 2004 | 03:18 AM
mightyjlr's Avatar
Here is my XM antenna...
Old Oct 21, 2004 | 07:00 AM
Heb80's Avatar
I have mine mounted in the same spot, except a couple inches forward, on the metal. How do you have yours mounted? Is it on there with tape or velcro?
Old Oct 21, 2004 | 02:51 PM
mightyjlr's Avatar
It's on there with tape.
Old Oct 21, 2004 | 06:21 PM
bmerfan's Avatar
Guys, silly question but how did you take the wire/cable for the antenna in to the car?
Old Oct 21, 2004 | 08:30 PM
Heb80's Avatar
mighty,
The instructions for my XM radio made it sound like the antenna uses the metal of the roof to enhance the signal. It stated that the antenna be placed something like at least 12" from the edge of the roof. I have mine mounted about an inch from the edge and it works fine. I'm assuming yours is working OK even though its mounted to glass?
bmerfan,
I ran my wire in through the grommet found at the top of the hatch. Then the wire runs through the headliner, the trim around the rear side window, down behind the seat belt, under the sill plate trim, then up under the dash, and out the glove box door where my Roady2 is mounted to the right hand center vent. The wire is hidden the entire way. Took a little while, but it looks good.
Old Oct 21, 2004 | 08:36 PM
mightyjlr's Avatar
I do drop the signal sometimes (rarely), and my installer said that as well. I don't really listen to XM that much to care though, most of my listening is through my iPod. I like how small the antenna is, and I think it makes the car actually look better.
Old Oct 21, 2004 | 08:47 PM
REDCROSS's Avatar
Honorary -C-I-C-C-I Member
Talking Re: Where to mount a Satelite Radio Antenna
Mine is mounted on the top of the dash and I have had no problems.
Old Oct 26, 2004 | 01:57 AM
ben's car audio's Avatar
We just completed an install on a customer's xfire. I ended up placing the xm ant inside the glass, in between the blk plastic of the third light and the interior trim. I like getting sat ants as high up as possible. One of my personal cars is an Acura Legend with a sirius ant stuffed in the dash just below the windshield- doesn't work so well - if the car is traveling northwest and the sat it's trying to see is in the southeast then that big grounded chunk of roof gets in the way. The third light location allows the ant a 360 deg view much lower on the horizon. As far as ground plane issues- it theoretically shouldn't work as well without , but in practice it doesn't care much.
Old Oct 26, 2004 | 04:48 AM
REDCROSS's Avatar
Thanks for the "Experts" input.
We are a bunch of Rookies just trying different ways of doing the same thing!!
Old Oct 26, 2004 | 02:02 PM
We also did a Bel RX75pro radar/laser detector with laser diffusers on the same car. Let me tell you, it worked perfectly. We mounted the diplay into the headliner, above the domelights. The (2) front diffusers went into the front grill on custom built metal brackets, bolted down to factory bolt locations. Here are a couple pics to look at.
Old Oct 26, 2004 | 03:04 PM
bmerfan's Avatar
nice job on the install.
Old Jul 5, 2005 | 07:43 PM
jjarocki's Avatar
Sorry, what is the "third light"? Do you have better pictures?
Old Jul 7, 2005 | 02:38 AM
jjarocki; the third light I was referring to is the center brake light. You have to disassemble the plastic trim around the rear window to get to it... but it by hiding the antenna in the light under the glass it is totally hidden from view, still maintaining excellent performance.
Old Sep 16, 2005 | 12:52 PM
2005-SoCalXfire's Avatar
Has anyone done an install on a convertible Roadster?
Old Sep 16, 2005 | 01:31 PM
kmarei's Avatar
i just installed it on a roadster.
i put the antenna in the middle of the top of the windscreen.
if you are facing the car,
right above where the rear view mirror is stuck on the windshield on the thin metal part of the car.
i ran the wire inside the rubber strip that runs along the top of the windscreen and down the same rubber strip to the inside of the car.
very easy to do and looks good.
if my description sux i can take a pic for you.
Old Sep 16, 2005 | 01:42 PM
jjarocki's Avatar
How is your reception?
