Transmission 6 Speed Stick clunk sound into second gear
Old Oct 10, 2013 | 06:23 AM
gualtira's Avatar
Question Transmission 6 Speed Stick clunk sound into second gear
When cold I notice a clunk sound when shifting from first to second gear. This is more pronounced when engine is cold. Any thoughts as to the source of this problem?
Old Oct 10, 2013 | 08:59 AM
ashonfire's Avatar
Default Re: Transmission 6 Speed Stick clunk sound into second gear
1st. to 2nd. gear shifts on a cold transmission are usually described as being hard, stiff, or notchy. Can't say I've heard anyone complain about a clunking sound though.
Does the sound seem to resonate from the transmission, or is it possibly coming more from the differential? (they are both so close together, it may be a little hard to determine).
After the car warms up, does the "clunking" seem to go away?
Old Oct 10, 2013 | 09:15 AM
gualtira's Avatar
I do feel some resistance going into second gear and it is not very noticeable when warm. As the weather had become cooler it is more an issue. I have only had the car for about 6 weeks it has 48K miles. Would changing to a synthetic trans oil be of any help?
Old Oct 10, 2013 | 10:19 AM
+fireamx's Avatar
The car comes from the factory with ATF III, and at my cars 36k check up the tech. installed synthetic Motor oil. I never really felt much of a difference. But I do feel the motor oil lubricates the tranny parts better than the ATF.
Most all of the manual transmission Crossfires seem to share the "notchy" 1-2 shift, Some are worse than others. Many feel it's less noticable if you're more aggressive when shifting. (Like taking it up to 3 or 4k in first gear, then shift). It's not very condusive to improving fuel mileage, but some feel it shifts better that way.
As I've said before, I've owned over 2 dozen different sports cars with manual shift, and the Crossfire is the worse shifting transmission I can remember. At least the 1-2 shift is. That being said, I still love it.
It just takes awhile to get use to.
Good Luck
Wes__Hutchinson
Jun 10, 2019 11:24 AM
velociabstract
15
Sep 7, 2015 03:43 PM
Just1n
Aug 8, 2015 11:45 PM
XFIRED-TX
Jul 17, 2015 11:56 AM
Rusty475
Jul 13, 2015 10:03 AM
