Anyone install a Clarion VZ709 in their XF?
Old Oct 19, 2013 | 07:36 PM
BibaResto's Avatar
Default Anyone install a Clarion VZ709 in their XF?
I assume not since Search came up empty. My main concern is how compatible it would be (other than being black) to the Infinity's wiring? I'd be fine with the Infinity, but i really want to add XM which the VZ709 is set-up for.
I'd also like to add a separate amp, and not only for the base. I can see where that could get tricky.
Also, is the antenna connection on the Infinity same as in the olden days or is it Infinity specific?
Old Oct 20, 2013 | 12:40 AM
Adrian_X's Avatar
Default Re: Anyone install a Clarion VZ709 in their XF?
From what I know, you'll need a Scosche adapter for the antenna connector when you swap out headunits to non-Infinity based ones. On top of that, you want the pre-out to be 4 volts for any replacement HU in order for it to play nicely with the Infinity amp our cars use. Overall, what I would suggest you do first is swap out the stock door speakers for the Inifinity Reference 6032cf ones. It will make a world of different in sound quality, and give you even better bass/highs control overall.
At 50 bucks, it's one of the best bang-for-buck investment you can make for the little Crossfire. I myself kept the stock headunit, but put in the above mentioned Infinity speakers in the doors. I use my phone with a bluetooth FM transmitter from GoGroove for my music needs. Anything from Google music to Pandora and XM subscription. Works very well, and when people hear the sound quality from the bluetooth FM transmitter they always ask for the price and place they can buy it themselves.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
