plug wires
Old Oct 23, 2013 | 08:53 PM
csteve0355's Avatar
Default plug wires
Anyone heard of or installed this plug wire set - they are available in 8.5 and 10 mm and in black red or blue.
Chrysler Crossfire V6 Formula Power 10mm High Performance HT Spark Plug Lead Set | eBay
Old Oct 24, 2013 | 07:01 AM
Default Re: plug wires
No, but for $30 less, you can get a set of Magnecore wires AND a new set of plugs from NeedsWings :
NeedsWings Ignition Kit Crossfire
( but then I see you already know this, as you list both in your sig )
Old Oct 24, 2013 | 10:53 AM
csteve0355's Avatar
Yes, I do have this kit installed. I'm not all that keen on the plug ends of the Magnacor wires -during install if you were not spot on and pushed to click onto the plug the wire would push back into the boot forcing you to go into the boot with long nose pliers to pull it back down to grab the top of the plug.
This set however comes with the OEM style plug ends, but you are right there is a big difference in price. The 8.5mm set that they sell is $50.00 cheaper.
Old Oct 24, 2013 | 11:38 AM
I posted this before, but will repeat it as you brought it up.
When I installed the Magnecor's originally, I 'thought' I had them on tight, and had no issues.
However, a couple of months ago, I installed my black crinkle painted valve covers, and while I had the covers off, I checked them again.
EVERY ONE of them needed seating. ( it's easy to do when you have the valve covers off. )
I'd even recommend removing the covers to do any plug / wire change, it's so much easier and you can be sure it's done correctly as you finally have good access.
Sterling57
Apr 11, 2016 06:11 PM
Sep 28, 2015 07:40 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
bobbie
Sep 12, 2015 12:49 PM
RiderJC
Sep 7, 2015 11:19 PM
