Differential rebuild
Old Nov 20, 2013 | 09:51 AM
Selbyl's Avatar
Default Differential rebuild
Looks like I'll be rebuilding my first differential soon. Today while taking my wife to lunch I noticed a loud rumble from 20-25mph. Hopefully it's just a bearing, anyone have any knowledge about this issue?
How hard is this to do? I have access to a lift and almost every tool under the sun I just need to know what I'm dealing with. This issue just started, I'm the third owner so I'm not sure when the differential oil was changed. If ever.
Old Nov 20, 2013 | 10:21 AM
grip grip's Avatar
Default Re: Differential rebuild
i have an extra spider gear if you're interested or you could just buy a different carrier off of ebay for under $300 shipped and save yourself a lot of labor and aggravation.
Old Nov 20, 2013 | 10:32 AM
Selbyl's Avatar
Shipping to Guam takes a couple of weeks to get things here. Can you provide a link for an 05 6spd carrier? Ebay is blocked at work.
Old Nov 20, 2013 | 10:34 AM
grip grip's Avatar
Car-Part.com--Used Auto Parts Market
Old Nov 20, 2013 | 10:49 AM
Selbyl's Avatar
Thanks, I'll have to figure out how easily I can get it shipped here. Usually takes 6 weeks.
Old Nov 20, 2013 | 01:13 PM
If it's just spiders, like Anthony stated. A lot of us have those lying around...
Old Nov 20, 2013 | 02:06 PM
Selbyl's Avatar
Looks like it's going to be about $600 just to get a carrier here so I may see about rebuilding mine. Shipping is pretty steep here. Thanks for you help guys!
Also can you clarify. what are the spider gears?
Old Nov 20, 2013 | 02:09 PM
the little gears labeled as #2 : ( planet, or planetary, or spider gears )
Old Nov 20, 2013 | 02:21 PM
Selbyl's Avatar
Diagnosing Differential Problems | West Coast Differentials
  • A howl or whine during acceleration over a small or large speed range is usually caused by worn ring and pinion gears or improper gear set up.
  • Rumbling or whirring at speeds over about 20 mph can be caused by worn carrier bearings. The noise may change while turning.
I'm having both of these issues I guess, the howl is around 20-25mph. I haven't noticed a change in the noise while turning but still can't rule it out.
Old Nov 21, 2013 | 01:53 AM
Selbyl's Avatar
So went to the Hobby shop and put it on a lift. Took me a little while to get the cover off. I didn't notice anything broken, but what do I know about differentials?? lol
I had the head mechanic come by and there's a few wear marks he said but no chips and or burn marks he said the fluid was probably just past it's prime. So I put it all back together and filled it up with RP 75w-140 and no more noise!! The car feels so much smoother now, I never noticed how bad it was before!
Valk
Jun 22, 2025 09:15 PM
thatcham
Oct 5, 2015 02:41 PM
eatmycrackers
Sep 23, 2015 09:08 AM
Diabla
Aug 20, 2015 10:50 AM
Selbyl
Jul 30, 2015 09:09 AM
